2018 Mazda 3 GT
Would an upgraded front sway bar offer any advantage on our cars or with my current setup?
I still have a little understeer that I wouldn't mind overcoming. It would also be nice to loosen up the back end a little in hard cornering.
Racing Beat Front Sway Bar
Not really much benefit for street driving. Better tires and a more aggressive alignment with more front camber and less rear toe-in will do more for you.
2018 Mazda 3 GT
Thanks arathol. I will give the alignment a try first, with the numbers you provided the other day.
You'll need parts....:wink2:
If you go for less rear toe in with factory parts you can't get the right camber. You need adjustable camber and toe arms to get alignment numbers that won't chew up your tires.
You'll also need a way to get more camber in the front.
