I'm with everyone here. A RSB is more bang for the buck. Chassis bracing does work if you have a lot of it but with just a single bar it won't make a noticeable difference at all (if any).Hey there!
Just a newb question here. Would it be beneficial to install a front strut tower bar on a stock Mazda3? Meaning no suspension mods.. Thanks!
Sway bars and shock tower bars are two different things for two different purposes. The sway bar stiffens the rear suspension, reducing body roll and changing how the car handles. The result is less understeer and more front grip.I'm with everyone here. A RSB is more bang for the buck. Chassis bracing does work if you have a lot of it but with just a single bar it won't make a noticeable difference at all (if any).
Besides most STB are for looks anyways.
The Progress bar works much better on the full stiff setting. The outer setting is not much more than stock. Don't forget to upgrade the sway bar end links.However, if I still want quicker turn in/less understeer, the next step would be the Progress RSB's (in their less firm setting). And if I want more improvement, will lastly add the Tanabe strut tower brace/bar, but I am not trying to change this car to an autocrosser/sports car circuit racer, just a "big fun" curvy country corner driver.
The Progress RSB works great & offers a substantial improvement in the softer setting. Had mine set that way for 1 1/2 years, with the stock end links, on my daily driver. Great handling, no problems. I think the stock end links are fine with stock springs or a mild drop, like my Racing Beat springs. If you go to a bigger drop, then the stronger end links would be advisable.The Progress bar works much better on the full stiff setting. The outer setting is not much more than stock. Don't forget to upgrade the sway bar end links.
If you are going to get a tower brace, go with the one piece Autoexe bar. The Tanabe is ok but is a multi piece that still allows movement. The single piece bar just works better.
You'll get better turn in from the strut bar than the RSB also.
I think you will find there is a fine line between an autox/circuit car and canyon carver street car.:smile2:
