1 - 20 of 25 Posts
Mazda 2019 BP AWD,
I have a massage on screen "Front Radar Malfunction" and "Safety and Driver Support System Partially Disabled".
Nothing works. I didn't use my car for a few days and after I've got that massage. It is still. I've cleaned front Mazda emblem, no change. SBCS is still off (second screen).
281792
281793
Does anybody have had any similar problem?
I would suggest Checking the Battery and also Checking with the Dealer to see if there are any recalls for your Car. I know that each of the Computers in the Mazda3 need to have constant 12V. If it dips below, the car will start posting errors. GL!
Też tak czasem miałem, zobacz czy nie masz brudnej szyby przedniej tam gdzie jest radar, mnie pomagało przetarcie, wyłączenie zapłonu i ponowne włącznie, wyszła nowa aktualizacja tsb w serwisie Mazdy na problemy z akumulatorem może to też być z tym związane.
Battery is 11,7V. It’s not a problem in my opinion. I disconnected battery for half an hour to reset but no change.
More "Z"s than I will use in sentences in the next 12 months
Is that 11.7v with the car running or not? If its running, thats a problem as the voltage should be at least 13.5. If its not running, its still a problem as the battery should be 12.5 or so.
The sensors need at least 12 volts to work. If the car is only producing 11.7v there is not enough power to go around and the sensors will start generating error messages. This is not a new issue, its been known for a few years now that low voltage to the sensor controls will cause this.
M3TH (Mazda 3 Turbo Hatchback 2021) Polymetal Grey PP
I had that issue before and they had to change a module from the rear. They asked me if I had a rear bumper accident. They needed to takeout the rear bumper. From ordering the parts to fixing it took at least a week.
Discussion Starter · #11 ·
Go to the service, let them upload new driver corrections in the car and it will be okay because recently something like this (TSB) came out, I have done and everything is ok
I'll go to mazda dealer of course, but it is last step I do.
I wonder if it is possible to do by myself with forum guys help.
Discussion Starter · #12 ·
I check once again and there is 11,8V with engine off. With engine on there's 14V.
Nothing can be done by yourself because you need a special tool that the dealer has because something has been broken by the mazda and pulls the battery currents, only for the service they will upload the driver correction and everything will be okay !!!!
Do not combine with the voltages because more than one checked it, I had this problem myself and the battery died 7x, after uploading the software by the service, everything is fine !!!
Nic się nie da zrobić samemu bo potrzebne narzędzie specjalne które posiada diler bo coś popsuła mazda i ciągnie prądy akumulator, tylko do serwisu oni wgrają poprawkę sterowników i będzie wszystko okej !!!!
Nie kombinujcie z napięciami bo już nie jeden to sprawdzał, sam miałem ten problem i akumulator mi padł 7x, po wgraniu softu przez serwis wszystko jest już dobrze!!!
Mazda 2019 BP AWD,
View attachment 281792 View attachment 281793
Try resetting the infotainment system and see if that helps. I replaced my windshield and the glass place didn't recalibratey scbs so Mazda replaced the scbs under warranty. If resetting it doesn't work take it back to Mazda. It should be covered under warranty
Discussion Starter · #15 ·
Problem solved. I went to Mazda dealer. There was not signal beetwen radar and CPU. It meant that radar was wrong or cable disconnected. It turned out that cable had disconnected close to front left wheel. It already works well.
Close topic.
Problem rozwiązany. Poszedłem do dealera Mazdy. Nie było sygnału między radarem a procesorem. Oznaczało to, że radar był zepsuty lub kabel został odłączony. Okazało się, że kabel rozłączył się w pobliżu lewego przedniego koła. Już działa dobrze. Temat do zamknięcia.
Close topic.
Good job. If anything goes wrong with the car take it in to mazda cuz after the warranty expires you are stuck with a defective car.
I got that warning message a few times usually on a hot day. Once I start driving the car, the error message eventually goes away. I notice this warning and the auto headlight warning come up usually on a hot day when I park the car under the sun.
Mazda 2019 BP AWD,
Try resetting the scbs
You can go into the settings on the infotainment and reset it. Press the music button, nav and press down the music button and press them down at the same time for a few seconds. That will reset it
1 - 20 of 25 Posts
