1 - 1 of 1 Posts
FRONT BRAKE DISC REMOVAL/INSTALLATION
SM2335158
id041100000100​
1.Remove the wheel and tire. (See WHEEL AND TIRE REMOVAL/INSTALLATION.)
2.Remove in the order indicated in the table.
3.Install in the reverse order of removal.
4.Depress the brake pedal a few times, rotate the wheel by hand, and verify that the brake does not drag.
am3zzw00022398
1​
Bolt​
2​
3​
Disc plate​
Front Brake Caliper Component Removal Note
1.Remove the front brake caliper component and suspend it in a place out of the way using a cable.
am3zzw00022399
Front Brake Caliper Component Installation Note
1.Push the piston in using the commercially available disc brake expand tool.
am3zzw00022400
2.Install the front brake caliper component.
1 - 1 of 1 Posts
