Part 1: The Issue (2016 Mazda 3 / 55,000 miles)
Hello, my name is Mark and this is actually my first post. Recently, I had an issue where my wiper motor kinda just gave out...or so I thought. As I am actually a mechanic I went ahead and got dirty, started checking the standard things related to wiper issues (fuses, grounds, continuity of cables and wiper stalk) and still NOTHING I basically thought a rat had just chewed the wires and I would need to completely dismantle the fuse box (which is VERY time consuming and tedious). Finally out of frustration I looked up wiring diagrams and that's when I figured it out! There is a component in the front fuse box called the front "body controller module" or "BCM" its a computer chip module that controls various functions like washer motor power/wiper motors actuation and power/etc. This module legitimately takes 30 seconds to remove (held in by two little thumb tabs). Since everything else looked to be in working order I thought I would start there.
Part 2: The Burning Wallet
So the next day I called up the dealership (yes I know more like stealership) I like doing it for fun mostly and to determine if they are knowledgeable, and let me tell you they are not. These hustlers quoted me $400... like what...that is absolutely insane! I asked him if that includes labor and he told me yeah it would take a while to "get to the part" I asked him again if he knew what I was talking about, again he explained "It should only take us about an hour to get to it" I laughed over the call and told him I got it out in 30 seconds and he got very quiet. Eventually I asked for the standalone part cost and they still quoted me $300 (which doesn't even make sense as he said hourly rate was $140 so the part would have been 260~ish). Since I'm broke, young, and don't like being swindled I went with alternative routes.
Part 3: Resolution
Save your money, time, and worry go to local pick a part or salvage yard. They even have vehicle inventory catalogs online so you can check if they have your vehicle. The BCM ran about 30 bucks, and guess what it fixed my wipers!
Part 4: Morals
What I have learned is that you should never go to the dealer even today... some things just don't change. It will always be more cost effective to either buy your parts online or at a pick a part/salvage yard if you are broke like me and just do it yourself.
Let me know if you have had the same issue and if swapping the BCM fixed the issue! Perhaps with enough issues Mazda may need to be notified as electronics shouldn't fail within such a short time.
Thanks, hope I helped.
Part 3: Resolution
Part 4: Morals
