41 - 44 of 44 Posts
This is the only relay I could find for this mod which pops 15amp fuse. Does anyone know where I can find relay where 85 and 86 are dedicated not on the same circuit.
278087
According to the wiring diagram @ the beginning of thread 85 and 86 are separate inputs. The relay that I’m using 85 and 86 are joined. Is this the correct relay to use because like I mentioned it blew 15amp fuse and never worked to turn on the fogs in acc
For anyone thinking of going down the easy route I would suggest otherwise. I’ve had no success with this mod.. I’m going to tap into the leads under the turn signal. Little more intensive however at least it will be successful.
41 - 44 of 44 Posts
