I have been thinking about replacing the Bose sub since the day I got my 3. At first, it was going to be totally stealthed inside the jack area. After taking the panel off and taking some measurements, I ditched that idea. I would have had to cut my interior up and I really didn't want to do that. I didn't want the sub under the floor and I didn't want a big, heavy MDF box.
The best option seemed to be the passenger side back corner. I took some packing peanuts of the same volume my sub would need and tried to get an idea of the space I would need.
Then I tried to work out how I wanted it to look with a rough Photoshop edit. This still isn't what I want, but it's an idea.
I carefully removed the bag of packing peanuts and traced the face of it. Then I changed the shape to something more like I want. This will be my baffle template.
The template and bag of peanuts gave me good idea of what area to fiberglass, so I taped it off and laid down about 2 layers of mat. No, the tape didn't leak
Before I laid the resin and mat, I sprayed Pam as a mold release. It worked pretty well, as most of the tape came off. There is a little wrinkle in the glass on the bottm, but I'll take care of that.
Here is a pic with the template to show the general shape I want.
This pic shows the depth of the notch I molded and how little floorspace the enclosure will actually occupy.
The enclosure WILL NOT be fleaced. Honestly, I think a lot of fleaced projects look horrible and they're just shortcuts. The contours I want will make it look a lot more OEM. To achieve this, I will be carving some stryofoam to put in the void and spraying gaps with expanding foam. The enclosure will be finished over that. When I'm done, acetone will dissolve the foam and it will wash out.
That's all for now
That's all for now
