So I got around to trying to figure out how I might get wires from the cabin to the engine so I could maybe make an independent Fog Light switch and I was wondering if there were any places to feed it through other than that main wire harness right in the driver side footwell.
Here's a pic of what I'm talking about...
And another just to be clear...
As you can see, there is a big Red wire going to it already which is from a Sub Install I got done a while back.
But from what it looks like, the guy just created a small hole in the Rubber part the protects the inside of my car from water and stuff.... But the hole seems tight around the Red wire, so I don't mind...
You can see where it feeds in to the engine compartment here:
Now, I'm not totally against making another hole in that rubber, I could just seal it with silicone later or something....
I'm just wondering if there is some special tool to help Make a hole in the rubber and feed the wire through at the same time, like a needle and thread I guess...
Either that, or some other place to feed wires through that would be easier....
Anyone have suggestions? :sweatdrop: :walkman:
I used a straightened wire clothes hanger with a very tight loop bent in one end (basically just bent the last inch and a half back over itself and squeezed it tight with pliers), attached my electrical wire to that end by twisting then wrapping with electrical tape. Then it was just a matter of poking the other end of the straightened hanger through that rubber boot. Actually I was unable to poke through it and ended up going through at the edge. I didn't notice any air or water leaks, but I did go back and seal it with some silicone just to be thorough.
Hmmm thats actually legit... I'll have to try it.... If I can find any wire hangers lying around, lmao...
I guess If I had any of those maybe I would have thought of it... thanks though - damn I posted this forever ago.
