I have had several places tell me that Eibach does not make a spacer to fit a '14? However, I know from the board there are several people running them.
Can anyone provide me with part #s for a 5mm and 10mm hubcentric set?
Thanks
[ame]https://www.amazon.com/5x114-3-Hubcentric-Wheel-Spacers-67-1mm/dp/B01MXEVVMW/ref=sr_1_1?s=automotive&ie=UTF8&qid=1523462446&sr=1-1&keywords=5mm+5x114.3+67.1+spacer[/ame]
I got these cheap 5mm ones for my front wheels. Torqued them down properly the first time around, and one more after 300 miles or so. 500 miles and no complaints.
I'd also be interested in going 10mm in the back, though that means I'd probably have to get extended studs. The Ichiba 15mm V2 have extended studs built-in and as long as you have cut-outs at the back of the wheels you are all set.
I had gotten these ones, rather similar to squelchy451's
I'm about 4k miles on 5mm spacers with no issues, they're thin enough I had over 6 lug nut turns. Any wider and, like above, I'd say you'd have to get longer lug studs.
