1 - 8 of 8 Posts
From September regular petrol supplied in the UK will change from the E5 to E10 formulation having a 10% bio-ethanol content. How much do people expect the fuel efficiency of the high compression SkyActiv G petrol engine I have to be affected by this change in petrol formulation?
My comment is pretty much useless I guess, but anyway. When I first got the car I used E10, I changed a few months later to E5 (we can choose :)) because supposedly it is 'better' for the engine. I found the engine to be somewhat rough at times, I was hoping this would solve it. Engine is running the same, no increase/decrease in fuel economy. I'm not sure if I felt any change in performance (E5 should give a bit more power?). All in all I did not win nor lose anything (aside from the slightly higher fuel price) ;-).
Did you mean the engine was rougher using E5 or E10?
Reactions: perseus
So no noticeable difference between E5 and E10, still 'rough' running at times and a bit jolty/jerky (during acceleration for example), so using E5 did not fix the 'issue' I'm having :).
I have no rough running on my 2.0 SkyActiv G other than the initial 1 minute warm up period.
That's one of my few criticisms of the 3, it's a bit jerky at times. I've been meaning to see if ethanol free from Shell or the like helps with that. Anyone do any tests?
Not able to here since it's all E10 but I'm going to throw a guess out there at it being due to the emissions systems. Emissions is why we have Rev hang with the manual and that can definitely contribute.
My e skyactiv x is definitely worse on fuel since E10 came out, on an identical run of 90 miles on the motorway which with E5 gave me a best figure of 61.4 mpg with E10 that dropped to 58.6 not a great difference but still nearly 5% which I suppose you would expect, is E10 the same 95RON? with a compression ratio of 15 to 1 I would expect it to be more affected than normal petrol engines, it definitely seems to pink a bit now under load.
1 - 8 of 8 Posts
