1 - 10 of 10 Posts
Is it possible to create a functional backup SD of these newer cards? I’d like to poke around in one without toasting the original.
Sent from my iPad using Tapatalk
yes , you can. i did a copy original sd card and backup copy in p/c and one backup copy sandish sd card .
working perfect backup copy.
If thats the case then why is it everyone is having problems backing up the card and having problems using the backup. Me included.
Don't know. Use a PC as a MAC leaves hidden files the CMU does not like, Format FAT32, Drag and drop the folders "content" & "license" and file label.txt to the new card. The copied card also will update just like the original. I use two 16GB Transcend cards that I swap back and forth when a new map update comes out.
276966
For the European cars, SD cards have tight security for which imaging is the answer rather than copying. I used win32diskimager to make an image of my Mazda SD nav card and to copy that image to a backup SD card. Both SD cards work in the car - see Win32 Disk Imager
Both cards are locked to a single car's VIN.
Om Shanti Shanti Shanti O
No nead Win32 Disk Imager or other programs. Just copy the all files of the Original card to a new one. A prerequisite for the original card to be updated in the Toolbox
That method didn't work on the SD card for my UK car when I last tried it 3 years ago
1 - 10 of 10 Posts
