Does anyone else have this issue?
When I wind down the drivers side window, and then wind it back up again, it comes out of the door wet! Has anyone else experienced this, should I be worried that there is a lot of moisture inside my door? or could this just be damp seals from previous rain?
I have the same issue...
But only the same day when I wash my car with miniwash, or when it's raining I think
The other day it's gone
I think this is not normal, on the other windows this is not the case
normal
no car door is waterproof
if you look closely all car doors have drain holes at the bottom to let the water out
If your window still comes up wet after about a week since it rained or you washed your car then you have a problem, check those drain holes they can get clogged
Reactions: Bruns
Working Class Hero
Same issue. The weather strips hold the water a while.
Sent from the wrong side of the tracks.
Thanks guys, I thought it would be normal operation a few hours after a wash or rain, will go to Mazda if it persists for days/weeks after. Though the chances of the UK staying dry for weeks is slim.
