What year? Ours (2019) has had and still has the defective front door seals/glass channels etc. We get the occasional rattle etc. from the 'window' area on front doors. This problem is a known one, and noise may be one of the results of it. The correct fix for it is now available here in Canada; parts have been ordered. There is a TSB covering this (attached).I have a similar issue.
B pillar / window glass rattle
My mazda has some rattle coming from the b pillar area while driving on uneven roads, this is especially noticeable during low temperatures. I've managed to locate the source - it's the drivers seat window. The rattle stops when I lower the window or push the window from the inside with my...www.mazda3revolution.com
It's noisy mostly during cold weather, it usually stops squeaking when I place my finger against the window glass or when I lower the window.
My friend who also ownes the new mazda 3 has this issue as well.
Mine is also 2019.What year? Ours (2019) has had and still has the defective front door seals/glass channels etc. We get the occasional rattle etc. from the 'window' area on front doors. This problem is a known one, and noise may be one of the results of it. The correct fix for it is now available here in Canada; parts have been ordered. There is a TSB covering this (attached).
YesI have a similar issue.
Yes, I think we have the exact same issue. This happens when it's cold and goes away when the car gets warmer. If I push the window from inside the noise goes away.I have a similar issue.
Maybe I should print this and show it to the dealer.What year? Ours (2019) has had and still has the defective front door seals/glass channels etc. We get the occasional rattle etc. from the 'window' area on front doors. This problem is a known one, and noise may be one of the results of it. The correct fix for it is now available here in Canada; parts have been ordered. There is a TSB covering this (attached).
You mean here?Does anyone have noise from window squeaking sound? I changed the glass run and it seemed okay for the summer and it came back now when it's getting colder.
No, the driver's door window make the noise.You mean here?
Worth a try. The TSB is for NA; my dealer just ordered the parts, which have to come in from the U.S. As I said, the defective front door mouldings/glass channels are a long-standing issue on the new 3s. The usual symptoms of the problem are one or more of visual warping, sticking front doors, and tears in the vertical rubber seal/garnish on the pillar.Maybe I should print this and show it to the dealer.
Watch out for the airbag 🤞🏾I should just disassemble the door panels and find out for myself. I don't think Mazda will never address this issue.
1. Disconnect the negative battery terminalWatch out for the airbag 🤞🏾
Ok, front door trim removed... now what?
He disassembles it so easily
Correct ... it does not. However, my point was that there could be a connexion between the defects it does address and squeaky/rattling front windows. I've no idea whether there is or isn't -- should know in a few weeks -- but it is a possibility. Just something for the op to keep in mind.From my perspective it doesn't look like that TSB addresses the issue with the squeaky/rattling window.
I guess now we look for any loose bolts and stuff? lolOk, front door trim removed... now what?![]()
