41 - 53 of 53 Posts
@Vadmmc can you disconnect park assist button, simulate is it working without it? if yes, please elaborate how it function. Do you have wiring diagram to connect sensors & buzzer?
I installed the front parking sensors with shirtcords
still waiting for the panel with parking button and rear buzzer
but I thought I can use for scan and code everything now
UNFROTUNATELY when attempting to write IC ASBUILT forscan says - wrong configuration and cannot write
do you think it is possible that lack of the button connected may cause that ?
When you modify IC configuration you need also to modify block 4, if you enter all modified data into IC excel file it'll calculates new block 4 for you. Write this new value in Forscan.
Okay. Coding succesfull but i got error B1B36 front right sensor - open circuit
do you think sensor may be fault and need replacement?
Swap sensors if problem travel to your left is the sensor if problem stays the same it's wiring. Try swapping shortcords also. Don't have an answer for your second question, it'll take a look at the service manual.
[QUOTE = "Bekir Demirtaş, posta: 2460999, üye: 522273"]
Mazda cx-3 ön park
Merhaba Vadmmc
2017 model mazda cx-3'üm var
1.5 tam kapsamlı dizel skyactive power sense sadece arka park sensörleri orijinal üzerinde bulunur ve cmu görüntüleyin görsel olarak görülebilir
ama ön parklardaki yok
DH0M67UU0 park sahibi var
ancak tüm kabloların bağlı olmasını düşünüyorum
Modülün iç bağlantı şemasını bulamadım
teşekkürler nasıl yardımcı olabilirsiniz.
[/ ALINTI]
41 - 53 of 53 Posts
