1 - 15 of 15 Posts
Accidentally ran over one of those concrete parking stop things..ouch! It dented the rail at the bottom but does not seem like any other damage. Question - the frame coating is chipped, is it important to touch it up to prevent rust? I live in Southern California. Am I missing any other possible damage?
I slipped the clutch a bit in an effort to drive to back out but couldn't, probably put a little wear on the clutch.. it does not seem quite as grippy now or perhaps that is just my imagination!!
https://photos.app.goo.gl/KYeQ24LkLlfwaKer1
My wife did exactly the same to our car last week, what you chipped and bent is the lower fender frame, it might require special tools to re-position it back to place but it's nothing super serious and you can rest calm.
I did not do any touch up paint paint since I frankly doubt that it will rust at a rate that it will eat the entire metal sheet, but I might do it tough just to be on the safe side.
How fast were you going?
5mph perhaps? Actually what happened was that I was going to back out of the parking spot but for some dumb reason I decided to go forward to exit the lot. I failed to notice there were concrete stoppers as the area was very poorly lit - we are talking about an open air parking lot here not a building. There was a bit of play between the tire and the stopper so enough momentum to jump it. I did not launch very hard or anything just a normal start so it was just enough to jump the stopper and fall back on the other side. Also, the stopper was a small piece so the left tire did not jump it only the right side. I eventually had to do sort of a 3pt turn to get out of the situation.
Just hit it with some spray paint to seal it up and carry on, sh*t happens.
Clutch is likely fine, likely your imagination and guilt / worry about knowing what you did LOL.
Reactions: kms1990
Demon Spawn
what he said. i cant tell you how many cars i see with bent pieces like that from that exact thing. i laugh at the lowered honda guys that bitch about bending shit when their car sits not but 1/2" off the ground. cluttch is likely your imagination getting anxiety over this, i know how that goes dont worry about it
the 2x4 that I use on top of the floor jack arm/cup pushes against the rail when I lift from the jack point:frown2:
I probably just suck at finding the lift points lol.
If you want to be cheap: get a hockey puck and cut a relief in it to lift on the body around the pinch weld instead of the pinch weld itself.
If you want to be baller buy a pinch-weld adapter plate for your jack.
Do not cut a slot in a piece of wood to use as an adapter, it can weaken and crack / break out of position while under load.
1 - 15 of 15 Posts
