You can just rename ExitLogo.ivf to TranLogo.ivf and use it, also be sure to replace TranLogoEnd.ivf cause the animation uses TranLogo.ivf + TranLogoEnd.ivfI'd sure like that. Seeing the old red coins, even briefly, could be fixed.
Actually I just found on other thread that the startup routine uses 3 animations:You can just rename ExitLogo.ivf to TranLogo.ivf and use it, also be sure to replace TranLogoEnd.ivf cause the animation uses TranLogo.ivf + TranLogoEnd.ivf
LoopLogo, TranLogo and TranLogoEnd
You can use:
LoopLogo + ExitLogo + LoopLogo again
Just rename the files and upload them to your mazda using ssh
Thank you @fitisgo I have done it like what you told. And fiolla its looks like stock again (the fuel consumption bar, and green ecu consumption)lol, thank you very much mate!@mrnerdbanger - are you aware the Pandora logo is sometimes not the color desired from the downloaded package? Did not know if this was intentional or not. The Pandora one for the blue package is kind of a mustard yellow baby poo green.
@richiealexander - I think this is the issue I am talking about above. My suggestion is to download the RED DEFAULT package and replace the icons you want. What you'll do is open the red and blue side by side, go through the blue folders to see which icons you don't like, copy the ones from the red folder the corresponding folders on the blue version. You'll then reinstall over the old installation as normal. No big deal, a little time consuming maybe 10-15 minutes but you'll get what you want.
I suspect mrnerdbanger ran all the images through a batch hue processing while working with one of the OEM red colors, that would explain why his color change from red to blue looks great, but some of the icons -- your fuel icons for example, and the Pandora logo are off-key.
@epadillacAgree, I am working on an iOS look, but there is a lot of images that have to be replaced, I think I can have something in a week
Of course, the main problem I have is that is not complete, some images are still blue or metal (I used the blue theme as base), how can I give you the images?
the nav uses a different system for its images (they are all bmp and I can't seem to open them with any editor). There are some files with a bunch of RGB values that I've been meaning to tamper with but I think the easiest way for us to get a blue nav is acquire the nav files from someone with a Scion iA because they have an OEM Blue Infotainment system. I know there are people on this forum with that car so....hi folks!
Today I install the blue theme with AIO 1.43. And now all screens are blue, only the navigation screen is genuine red. Any ideas? Fw is. 511
Thanks!
@Siutsch
Thank you! :smile2:@Siutsch
Here is what I have for now:
jci.zip with all the files to make it as a new theme on your installer:
https://www.dropbox.com/s/qecjjvoy139khpd/jci.zip?dl=0
installation txt for your installer:
https://www.dropbox.com/s/wx4g75s9pgxk97x/05_ios.txt?dl=0
Also here I attach the installer for the transparent buttons with a tweak to have a bigger album art:
https://www.dropbox.com/s/79t9gmq2d2eef81/NoButtons-bigger-album-art.zip?dl=0
Here is a screenshot of how it looks:
https://www.dropbox.com/s/k9ztp0zqbrjok1a/MZD iOS Theme Screenshot.JPG?dl=0
I am making tests to see if I make it work with your installer but I am still struggling with that, if you can help me with the integration I will appreciate it.
Thanks for all the work you put on this installer and helping the community.
Thanks, I already made tests on my machine and it was no trouble at all integrating it, I just added / modified a few filesThank you! :smile2:
You don't have to help me to integrate it within AIO, that's my job!
I will have a look at this and hopefully it will be a part of AIO 1.44, then with new Speedometer 4.0 too (speedo and videoplayer then in app menu).
Hi again @Siutsch, I re-zipped the files cause it had those annoying "_DSStore" files that mac generates.Thank you! :smile2:
Thanks, I deleted them allready.Hi again @Siutsch , I re-zipped the files cause it had those annoying "_DSStore" files that mac generates.
Here it is: https://www.dropbox.com/s/qecjjvoy139khpd/jci.zip?dl=0
Send me a pm if you want help with anything
@Siutsch Maybe I left my original backup files there for the files I made modifications, please delete all the files that end with "png_original" or something similar.Thanks, I deleted them allready.
One question:
The color schmemes from mrberdbanker have 1289 files.
In your Zip there are 1343 files, 54 more.
If I use the red scheme to uninstall, I think there will be these 54 files, that are not copied with the originals, or am I wrong?
Thanks.@Siutsch Maybe I left my original backup files there for the files I made modifications, please delete all the files that end with "png_original" or something similar.
Thanks for cleaning it up @SiutschThanks.
These were not the only files, there were some files with 'copy' and 'modified' too.
But now it fits.
