Could be your subframe (aka engine cradle) bolts need to be tightened? Just a guess.
Possible ball joint?Hi Guys,
Been a while since i posted anything! I have recently heard creaking noises when turning my wheels. It sounds similar to a squeaky door or frog croaking. I'm on airlift performance air suspension. Anyone have any ideas on what it could be and if it would be easy to have it repaired?
Thanks!
I had this issue. It's a wheel bearing.Hi Guys,
Thanks!
Did you have it repaired and did you take it to a shop or do it yourself?I had this issue. It's a wheel bearing.
I had a wheel bearing replaced by a mechanic. Definitely something that should be fixed.Did you have it repaired and did you take it to a shop or do it yourself?
It has been replaced by the warranty??I had this issue. It's a wheel bearing.
