1 - 6 of 6 Posts
Hi everyone,
Recently bought a M3 GT 2017 and need to pass vehicle inspection. It is mandatory here to front fog light to illuminate on the dash. So... I found this article Fog light dash indicator
Whats said.. that this light is disabled from the factory, but the fog lights work. So I did some research and testing.
Connected to Forscan, checked AS Built code for IC.
According to my 720-01-01 i have US Region. But that does not mean it wont show up a fog light indicator?
Also found this from previous posts:
HI,
I have Mazde 6 from 2017, I need to activate the rear fog.
I tried to follow the instructions "Fabiomaster"
"Front and rear fog light indicator.
IC, 720-01-01, B0 – b1 i b0 change to 1, b2 i b3 change to 0. Region change to EU - active front fog light indicator on cluster ( if you have NA version You must change cluster to EU version )
RBCM, 7B7-01-01, B0 – b2 change to 1. Activates rear fog light on pin 4Q (blue harness). Also activates orange rear fog light indicator on cluster.
Discussion Starter #2
275088
Maybe my checksum is incorrect? Tried coding this, but no luck. Light did not appear when I use the switch.
your checksum is ok for 07 20 01 01.
and for RBCM 7B7 01 01 in B0 what have you changed, b2 to 1 and new checksum ?
Some instrument clusters don't have that light at all. Others it's deactivated when on the US region. You would have to switch to a different region to enable the front fog light indicator.
Thats what the initiator of this thread already figured out 2 days ago (see this post in another thread). As he opened the same question in several threads and his question is already answered, I do not think that continuing this thread here is necessary anymore.
1 - 6 of 6 Posts
