1 - 9 of 9 Posts
Here's the rundown: 2008 Mazda 3s manual hatchback:
It started with stumbling/stuttering issues at around 2000-2500rpm while cruising, light throttle, maintaining speed with traffic flow. No codes thrown. Looking around the forums, it seemed like cleaning the MAF sensor was the consensus, so I tried that. Cleaned it with MAF Sensor Cleaner, let it dry, reinstalled it, and OH-MY-GOD-IT'S-SO-MUCH-WORSE. The mild stutter or stumble became a full-on bog, cough, die-at-idle, hell-to-keep-running kind of issue, and immediately threw the P0102 low voltage code.
I replaced the MAF sensor with an aftermarket parts store unit, but that didn't do the trick. My wife was out of town at the time, so using her car as my baseline and guinea pig wasn't an option.
Fast forward to this morning, when I finally had access to both cars and time to play. I pulled the original OEM sensor from my wife's car, plugged my original unit into hers, and drove it for about 30 minutes. No issues at all. No stumbling, no codes, no problems. That's good. That indicates that the original unit wasn't faulty in the first place.
Now the acid test: I put her known-good OEM unit into my problem-prone car, and went out to drive the same loop. I had to abort pretty quickly and head back to the house, because the stuttering and bogging came on just as soon as the engine warmed up, and the car died several times when I had to stop for red lights.
The P0102 code came back, of course, just as it has done every time since I cleaned the original sensor last weekend.
No other codes have popped up.
This leads me to believe that I have a faulty wire in the MAF sensor's harness. Has anyone else had similar experiences and found the solution to be something else, something I haven't considered?
I'm not really in a position right now to just throw money and new parts at the car, and I'm pretty terrible at troubleshooting electrical stuff (it either works, or it doesn't, in my book. :) ), and if I ever owned a voltmeter, I have no idea where it might be now, or how to properly use it if I could find it. It doesn't help that I really don't have a place where I can properly work on the car for any kind of extended time frame.
Just trying to get ideas and verify if I'm on the right track or not before I try to get it to a shop and let them have a go.
Thanks in advance for any advice and help.
Discussion Starter #2
Dang it - I meant P0102, not 0101. Sorry about that. :(
Went to a junkyard and found a 2nd-gen 3 with the same MAF sensor connector, and the 2g 3 has about 10" of extra play in the wiring harness for that sensor, so I clipped that out and they charged me nothing for it. Wires were different colors, but I used the old sensor to make sure I was splicing the right wires together. Been four days now, and no codes, no sputtering or dying. Seems to have fixed the issue for the most part.
There *is* a weird kind of flat spot under wide-open throttle, between around 4000-5000rpm, where it feels like the engine just isn't getting enough air. I say it's weird, because if you're cruising around at 3000rpm or so, and roll into full throttle from there, you get that flat spot in the acceleration. However, if you launch it and go full throttle from the jump, it seems fine. I'm going to keep playing with it to see if I can figure out what's what, 'cause I want my 3 back the way it was, and something's not quite right.
aka Goodwrench
You may want to pick up a cheap ELM327 OBD scanner and a good OBD app like OBD Fusion.
Then you can view or datalog the output of the mass air flow sensor or any of the 30+ additional sensors/PIDs.
Also you can view your fuel trims in real time to see where the fuel mixture is... rich or lean.
I just had an issue with the mass air flow sensor on my 2010 Mazda 3. After trying to clean it with no luck, changing it out with a new Delphi sensor with no luck, and changing again with a Duralast sensor with no luck, I took it in for a diagnostic test. Everything was reading (not well, but reading) which ruled out wiring issues. No vacuum leaks. It was recommended that I try using a Denso sensor or a genuine Mazda sensor. I went went the Denso and PROBLEM SOLVED. Moral of the story is buy a Denso sensor because sometimes these cars can be finicky depending on the sensor which will throw on the check engine light over and over. OEM parts are the only way to really fix the issue so don't go with anything else!
For control system input/output devices OEM parts are the only way to go. The copy products look the same but there are always subtle differences that cause problems.
For my MB SLK I have to use a Bosch or Pierburg MAF , even though they cost roughly 10 times as much as copied parts.
The Delphi sensor would have probably worked on a GM product, as GM own Delphi.
UPDATE: Aside from using OEM parts, if your CEL issue is still prevalent after changing your MAF sensor and you've found no leaks, wiring issues, etc. check the MAP sensor. Mine was all clogged up with sludge. No airflow through the sensor obviously would cause a disruption if it cannot detect anything due to congestion. Sometimes this can throw the P0101 code. Fixed mine!
Sorry I havent read the complete thread so I hope I'm not doubling up on answers..
I have 04 sp23, It seemed to develope MAF issues just after buying it a couple years ago.
On some models, there is actually a fault with the Ground wire on the MAF sensor harness..
To rectify you need to cut a small section of the black ground wire at least 25mm from the plug,
remove the female connector and replace that section.
1 - 9 of 9 Posts
