Hi all
Picked up a 2017 Mazda 3 last week and am having an issue while using Pandora. When I go through the menu to browse my stations and select a station, 95% of the time nothing happens. It stays in the same station. Anyway to fix this or get the station to change? I can't even use my phone to do it because it is in that special Pandora accessory mode.
Thanks for the help.
· Working Class Hero
Do you have a Pandora subscription? The head unit may only operate in a demo mode until you enter your user info. If you are a subscriber, you can use your phone through the Bluetooth link.
Hi,
I don't have the pay subscription to Pandora but i am logged in (and therefore can see all of my stations on the headunit). I tried uninstalling Pandora and re-installing but hitting the same issue. I was able to change the station the first time today, but then nothing happens if i try changing again. I'd rather not use Bluetooth for this because i want to see the album art and i would like to be able to give "Thumbs Up/Down" directly from the headunit.
Also, i have an aftermarket Alpine unit in my other car with the Pandora interface and I can control that one with no problem. I'm running the latest US firmware if that matters which is v59 or something like that (and IOS 10 on the phone)
Any other suggestions are welcome! I will also try to contact Pandora.
Thank you for your help.
