Ok - got some progress.
Today module GMC8-67UU0-C arrived taken from Mazda 6 2016 D SE-L NAV .
After the module swap got the front layout instantly - I can't even turn it off with the Excel file.
a) Front Sensor are all working and got a beeper working.
b) activation button is still dead and not working (tested every possible configuration)
c)I lost the beeper for the rear sensor (I'm not sure do I have a connector for the rear sensor - is it next to the R-BCM unit?) but now the beeper which is located on the front earlier was working as the rear sensor sounder - now is designated to the front sensor.
This is now solved - I need a rear buzzer to be installed
d) DTC incompatible config is present and impossible to clear
Now I'm not sure is it because the module has -C or something else.
I have ordered another module - pure GMC8-67UU0 without C and gonna test it again.
Is there anybody out there with Mazda 3 2017/18 BN with working Front and rear sensors, who could share IC data and P/N of the PSM unit?
e) I got one now! thank you @AndyH ! looks like my config is almost identical! only bit is Bose System (I have read somewhere those bits are also responsible for PSM? I think activating Bose will give me additional DTC)
TBC
EDIT:
f) Module GMC8-67UU0 without C arrived but unfortunately the same problem. The button doesn't work and DTC WRONG CONFIG.
g) when I swap module from B61A-67UU0 to GMC8-67UU0/GMC8-67UU0-C front sensor start working immediately and I can't turn it off with as-built config. Also DTC is imminent. The last resort to have it work is module from the BM model mentioned before
h) there is a chance that my car will be "wired" for a button in the panel next to the steering wheel?
This front sensor mission is gonna kill me.
c)
TBC
EDIT:
