6601 - 6620 of 6657 Posts
So today I finally tried the speed correction on my car, which is Mazda 3 BM 2015.
Right now I have 225/40 R18 tires, and when I'm driving at 50 kmph, GPS is showing ~47 kmph. When driving at 100 kmph, GPS is showing ~95 kmph.
I've made following changes in the file:
After Writing the changes, I got following DTC errors:
I've performed SBS/MRCC module initialization/relearn from Central Configuration. It fixed the DTCs.
Tested the speed - but noticed no changes. It was still different from the GPS at approximately the same value as before changes.
Before:
;Block 4
720G4G11C500080FF17
720G4G9C10400000700
720G4GAB50000BF01B0
After:
;Block 4
720G4G11CF10080FFB8
720G4G9C104000006FF
720G4GAB5A200BF0152
Has anyone managed to make it work using the Excel file?
I'm noy sure why you want to have exact measurment
I'm aware of a difference either on my motorbikre or car - it is always approx 7% of a difference. I like to have it. I'm talking about speed cameras here
Before:
;Block 4
720G4G11C500080FF17
720G4G9C10400000700
720G4GAB50000BF01B0
After:
;Block 4
720G4G11CF10080FFB8
720G4G9C104000006FF
720G4GAB5A200BF0152
I think i got it but im confused where to get the general checksum on 720 04 01 ?
Mazda 3, 2015, SkyActiv, 1.5L, 120hp, 6AT, Touring+, Titanium Flash Mica
ok I went through every possible combination and looks like I will use black tape over the Amber-A to not see it.
1101 (LAS w/o HBC) doesn't kill HBC as I still see it in the Lighting menu. At least I tried ;-) Maybe one day we will find a working solution
Btw - should I see Both LDWS and LAS options in the menu? Or LAS includes LDWS so only LAS should be visible in the Safety tab? When I was playing with combinations sometimes I saw LDWS and sometimes LAS in the Safety tab
Just install the proper wiring harness adapter so the LEDs are configured properly and the lights can work without generating error messages.....
I didn’t do anything with my lights which are Halogens from the factory (only with LED bulbs but they don’t throw any errors)
lights are working correctly I didn’t test HBC as I don’t have any dark roads anywhere close by
DLR HB and LB with H11 and H15 in manual and auto mode - everything is spot on. Amber-A what I’ve read is a well known issue - only one thing I don’t understand is why I can’t disable HBC system and keep LAS and LDWS
Amber-A problem fixed with black lx tape.
I took IC out of my car - and put a piece of black PVC tape between HBC “window” and Green/Orange LED - blocking the light. Now amber-A is no more visible. Pretty ugly solution. It looks stupid but if it works it’s not stupid ;)
Rectangle Font Plastic Creative arts Paper
Vehicle Speedometer Car Tachometer Motor vehicle
  • Haha
Reactions: SergSlim
LDWS is a subsystem of LAS, so to say, or vice versa.
So when you have LAS activated, you should see only it in the Safety menu. However, LDWS should be present INSIDE of the LAS submenu as an option with a checkmark. I don't remember how exactly it is called in that menu, though.
it is exactly what it looks like! Thx for confirmation :)
So i did couple of test and it works.
I followed the calculations and also using the excel to find the B5 checksum for 720 04 10 because i have a new B1
I dont have to change anything on 720 04 09 but if your setup needs to have different B4 then i guess you have to.
calculate the new general checksum for 720 04 01
then using forscan, i did put everything manually and not the whole 720 04 block
I also put the new B5 checksum to 720 04 01 from the excel but forscan changed it to different one.
Got some warnings about rf keyless something b4 i wrote it but everything went smooth, no errors or cel, and the speedo is now the same as gps speed.
Before:
;Block 4
720G4G11C500080FF17
720G4G9C10400000700
720G4GAB50000BF01B0
After:
;Block 4
720G4G11CF10080FFB8
720G4G9C104000006FF
720G4GAB5A200BF0152
right after some play with IC module my fuel level gauge started working in a VERY weird way. it shows a reversed value - I mean when it was full it was showing empty - and while I was driving fuel level slownly went... UP, up to approx 10% of my tank after 500 miles trip
I checked PID for fuel level and I restored my original IC config - PID shows 11% (which is correct) but the gauge shows empty. should I refill to full to reset the gauge or reset the IC module? Or is there any other way to have a correct reading?
  • Wow
Reactions: SergSlim
After refuelling everything back to normal but looks like the area I asked you before @SergSlim is responsible for this mess
Hi Maybe he will tell you how to beat in the factory condition so that my Mazda Cx5 car becomes equipped with the installation of a drive in the trunk instead of the usual one. Installed the original from the donor Wires, block, button, shock absorbers Error plg_mz u2300:56-0a is now on Central configuration Invalid or incompatible configuration
With a cruise like understood. Has come time for other useful functions.
I ask all who have a desire to connect to study.
Study SSU:
731-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B1 - it is (in BIN):
b7 - 0 or 1 = function is not known
b6 - 0 or 1 = function is not known
b5 - 0 or 1 = function is not known
b4 - 0 or 1 = 0 - I-Stop OFF, 1 - I-Stop ON (Tested on CX5)
b3 - 0 or 1 = function is not known
b2 - 0 or 1 = function is not known
b1 - 0 or 1 = function is not known
b0 - 0 or 1 = function is not known
B2 - configuration mode wireless control (step-by-step opening):
b7 - 0 or 1 = 0-W/O Advanced Keyless Entry; 1-W Advanced Keyless Entry
b4 - 0 or 1 = 1-W Unlock mode (2-step); 0-W/O Unlock mode (2-step)
b2 - 0 or 1 = 1-W Unlock mode (2-step); 0-W/O Unlock mode (2-step)
731-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
B0 - it is (in BIN):
731-01-03 B0 B1 B2 B3 (checksum) in HEX
B0 - wireless mode lock/unlock is ONLY displayed on monitor (for example it is possible to configure only display the "unlock Mode"(step-by-step opening) or together with "Lock when leaving car":
b6 - 0 or 1 = 1- NO visibility Lock when leaving car; 0 - visibility Lock when leaving car
b4 - 0 or 1 = 1-Visibility Unlock mode
b2 - 0 or 1 = 1-Visibility Unlock mode
Study RBCM:
7B7-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = 0 - no auto door lock or 1 - auto door lock (activates door lock function in RBCM)
b4 - 0 or 1 = function is not known
b3 - 0 or 1 = 0 - 1x blinker when doors close from remote control or 1 - no blinker when doors close from remote control
b1 - 0 or 1 = 0 - no blinker when doors open from remote control or 1 - 3x blinker when doors open from remote control (w/alarm system)
B4 - it is (in BIN):
b6 - 0 or 1 = 0 - OFF 1 - ON (ability to lock doors when Ignition ON) tested on CX5
b3 - 0 or 1 = 0 - OFF 1 - ON (ability to lock doors when doors open) tested on CX5
b1 - 0 or 1 = 0 - if engine work then not possible open boot or 1 - if engine work then possible to open boot (from button on boot)
7B7-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = no data on use
b6 - 0 or 1 = 0 - OFF Find My Car or 1 - ON Find My Car (Press lock button twice on remote controller, You will hear a shortly horn) tested on CX5
b5 - 0 or 1 = 0 - It does not allow to open the trunk in the Drive mode (D) or 1 - It allows you to open the trunk in the Drive mode (D) tested on CX5
b4 - 0 or 1 = no data on use
b3 - 0 or 1 = no data on use
b2 - 0 or 1 = no data on use
b1 - 0 or 1 = no data on use
b0 - 0 or 1 = no data on use
b6 - 0 or 1 = no data on use
b5 - 0 or 1 = 0 - no auto door lock or 1 - auto door lock (only for visible this function on CMU)
b3 - 0 or 1 = 0 - auto door lock or 1 - no auto door lock (only for visible this function on CMU)
7B7-01-03 B0 B1 B2 B3 B4(checksum) in HEX
b5 - 0 or 1 = Lighting Coming Home Light - ON
b4 - 0 or 1 = Lighting Coming Home Light - OFF
Study IC:
720-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B2 - it is (in BIN):
b6 - 0 or 1 = 0 - OFF Beeper driver seat belt; 1 - ON Beeper driver seat belt
b5 - 0 or 1 = 0 - OFF Beeper passenger seat belt; 1 - ON Beeper passenger seat belt
b4 - 0 or 1 = 0 - disable I-Stop; 1 - enable I-Stop (enable/disable button I-Stop and view logo "I-Stop" on Instrument Cluster)
720-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = 0 - Digital display Cruise control on IC; 1 - NO digital display Cruise control on IC
720-04-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B0:B1 - it is checksum for full configuration of car (IC)
720-04-14 B0 B1 B2 B3 B4 B5(checksum) in HEX
b5 - 0 or 1 = 1 - W ALS (Headlight Auto Leveling System); 0 - W/O ALS
b4 - 0 or 1 = 1 - and if b5 = 0, then AFS and ALS (Adaptive Front Lighting system) is OFF, if b5 = 1, then AFS and ALS is ON; 0 - and if b5 = 1 then only ALS is ON
720-04-23 B0 B1 B2 B3 B4 B5(checksum) in HEX
b6 - 0 or 1 = 1 - Cruise Control with LIM
b5 - 0 or 1 = 1 - Standard Cruise Control/MRCC
b4 - 0 or 1 = 1 - W/O Cruise Control/MRCC
720-04-24 B0 B1 B2 B3 B4 B5(checksum) in HEX
b5 - 0 or 1 = 1 - SCBS ON; 0 - SCBS OFF
b4 - 0 or 1 = 1 - SCBS OFF; 0 - SCBS ON
720-04-27 B0 B1 B2 B3 B4 B5(checksum) in HEX
b3 - 0 or 1 = 1 - REAR CAMERA with DYNAMIC ASSIST LINES (7 wires) ; 0 - REAR CAMERA with FIXED ASSIST LINES (4 wires)
for example:
edit string in configuration
7B7-01-03 0018 5400 2E
on
7B7-01-03 0018 9000 6A
adds features:
  • RAIN SENSING WIPER
  • AUTO HEADLIGHT ON
String 7B7-02-01 no need to change. This string enables/disables activated features, it can be done in media settings.
Connect to study.
hi i have a question about "disable i-eloop" at 4th block how to disable it.thank you and
best regards
I tried values from the spreadsheet on MX-5 2019 and it did not work - I have the exact difference in the speed as it was before. No changes.
PS: I also check the calculations in the spreadsheet and all seems to be correct.
PS2: I check AsBuilt data I have from three MX5s (2016/2019/2020) and all of them have the same value in B4B1 = 0700. And when I tried to put some weird values into B4 I immediately got "vehicle malfunction" and speedometer & RPM gauge turned off completely.
