Idi na..i rus……… - english forum hereздравствуйте, скажите мне, какие значения я должен изменить, чтобы отключить i-stop?
I've successfully completed a BSM retrofit on a UK Mazda 3 Hatch, but this is still nagging me! Like SergSlim, reeeeeeee and Skywoon, my left radar is RVM and Right BSM. I've seen a CX5 module list with BSM - L and BSM - R and can't help but think we're missing something. @Nikodim, does your OE BSM show the Left and Right Modules on Forscan?Can anyone with Mazda 3 BM, which has BSM send me a screenshot of FORSCAN showing list of modules after initial connection to car?
For some reason my left BSM radar is listed as RVM, though in description it is said left BSM.
...or anyone else with BSM fitted as standard on a 3 BM/BN 🤔I've successfully completed a BSM retrofit on a UK Mazda 3 Hatch, but this is still nagging me! Like SergSlim, reeeeeeee and Skywoon, my left radar is RVM and Right BSM. I've seen a CX5 module list with BSM - L and BSM - R and can't help but think we're missing something. @Nikodim, does your OE BSM show the Left and Right Modules on Forscan?
If it is possible in asbuilt then that feature hasn't been found yet. If you manage to find it, let us know. If you really want that feature, you can always get something like this:I was wondering,
I know some Mada models have the mirror dipping function when putting in Reverse.
is this also something that can be enabled?
I'm really trying to understand what you wrote but I just don't get it! - Try againhi can i ask mazda cx3 2017 Australia 2.0L IC asbuilt code can use japan or not cause the ori ic gone ady
sorry about that , i have one mazda cx3 import from Australia then i replace the meterI'm really trying to understand what you wrote but I just don't get it! - Try again
[/Q
after i replace this meter the a/c compressor also no working
So as I understand; You replaced the IC, (Meter) and don't have any ASbuilt data from the old IC. Did you try the load factory function in forscan? This uses your VIN to search for the correct ASbuilt data.after i replace this meter the a/c compressor also no working
You must carry over the settings from the old IC to the new one with forscan. I had the same problem when I replaced my IC.after i replace this meter the a/c compressor also no working
but the old IC all data lostYou must carry over the settings from the old IC to the new one with forscan. I had the same problem when I replaced my IC.
You can get your original configuration from the Mazda page with the VIN of your vehicle.but the old IC all data lost
ohhh i try latter thxYou can get your original configuration from the Mazda page with the VIN of your vehicle.
There is a tutorial in one of the excel tabs (CCC converter).
but what is the websiteYou can get your original configuration from the Mazda page with the VIN of your vehicle.
