How did you do this? I want to do the same to my mazda 6. Thanks in advance
I don't have cmu. I have the older nb1 unit. I just want to retrofit the gauges. ThanksUpdate CMU
Hi guy, I have my 2019 Mazda Cx8. My issue is mrcc cancel when speed is low from 30 km/hTo activate Stop and Go MRCC
To activate Stop and Go MRCC:
For those who own 17+ CX5 or 18 CX3 equipped with non-Stop&Go MRCC. Here is the instructions that I learned from a Taiwan Forum to activate the Stop and Go . Many 17+ CX5 owners have been thoroughly test it for few weeks along with LIM function and works like a charm..
(1) Download and install the latest Forscan release that can be found on Forscan website
(2) On 720-04-17,
change b1 of B2 from “0” to “1” (70 --> 72) and then
change b2 of B4 from “1” to “0” (24 --> 20), finally
have the hexadecimal value of B5 minus 2 to get the new checksum (4E --> 4C)
(3) Update the global checksum on 720-04-01’s B0B1 and B5 accordingly based on the changes made above
(4) Run Forscan’s ABS Relearn / Initiation with Forscan step-by-step instructions
(5) Run Forscan’s SBS/MRCC Relearn / Initiation with Forscan step-by-step instructions
(6) Clear all DTC errors and all set
He vuelto a subir las fotos del foro ruso al servicio público de imágenes.
Datos sin bloqueo automático:
Datos con bloqueo automático:
[/CITA]
Hola ¿este scaner sirbe para mazda 3 2019? porque instale el forscaner y es para Ford, si funciona para mazda ¿habria que cambiar en las dos primeras filas, ultima columna A3BB por A33B y 087B por 2093 respectivamente? agradecere su informacion
gracias
Hi TristanCheck if you have to change 7B7-02-01 as well.
I just checked your values... it seems to me that you forgot to change 7B7-01-02 B4 b3 to value 0 (Auto Door Lock = On = 0). New correct value should be: 7B7-01-02 A504 C368 9025
...and if writing blocks still fails, try to write each block individually and not all blocks at once. I think there was (perhaps still is) a problem with the button "write all blocks".
SentI have a 2019 Mazda cx-5 SUV.I want to change some of its configuration.Due to the Chinese government's supervision of the Internet, I can't download SergSlim's EXCLE tool.Even, I can't use Google,Youtobe and Facebook.So,who can send me the EXCLE tool?My email is [email protected].
Here, I would like to thank you and the experts who have made outstanding contributions to the forum.
I don't understand. Where to write it. In exel but where.Try BF03 400002200000
It is in IC tab.I don't understand. Where to write it. In exel but where.
It is in IC tab.
BF - is located in Block 4 of IC module.
If you look closely, you'll notice, that Block 4 has multiple bytes that are not editable, and inside of them you'll see BF 01, BF 02, BF 03, etc.
You can always watch Tutorial on how to use Excel file - it explains a lot.
Thanks after changing to BF03 4000022000000 the AFS error U2300 problem is gone butTry BF03 400002200000
