Most probably you did not change the checksum in 740-04-01 - see top row in your screenshot. This is calculated automatically and has to be changed every time you do changes in the 720-04 block.
According to his screenshot - he changed only 720-01-01 and 720-02-01 for some reason. No need to change checksum.Most probably you did not change the checksum in 740-04-01 - see top row in your screenshot. This is calculated automatically and has to be changed every time you do changes in the 720-04 block.
sorry, forgot to send.Post your values of SSU 731-01-01 and 731-01-02 and of IC 720-01-01. Then perhaps someone will calculate the new values for the i-Stop deactivation.
Otherwise see the video of SergSlim, check the XLS mentioned in his signature and learn how to use it. This is the base for the calculation. The XLS has a tab "Donate & Tutorial" in which a lot of features are mentioned. But beware - some of them require new hardware/wiring.
Thank you, Tristan.New values for disabled i-Stop:
SSU 731-01-01 is 5020 C004 208E
SSU 731-01-02 is 080D 1926 901F - stays as it is, no changes necessary.
IC 720-01-01 is 6301 6226 8095 - use the Write-Button, not the Write-All Button, as there might be problems using the Write-All Button as far as I remember.
After this change, SCBS stopped workingI finally succeeded, everything works without errors.
I did as tarahumara wrote : "I've changed 0720 0418 2845 F0BF 0665 to 0720 0418 600C F0BF 0664 and the checksum in 0720 "
From Configuration menu i relearn ABS and SBS/MRCC
Sorry you're doneFor those that do not speak Polish please at least post a Google translate version.
