5941 - 5960 of 6041 Posts
I found several VINs M6 '14 with Bose and no sunroof. If we take into account the bobstar_fr configuration, and also considering that the sunroof has nothing to do with the car, except for the power supply, it turns out that the sunroof has nothing to do with the configuration in IC. The only remaining option for B0, as Nicodim suggested, has to do with the presence of Bose. Auto with Bose on line 720-4-26 B0 = 20, without Bose B0 = 10. for the first generation CX-5 without Bose B0 = 00, for the second generation without Bose B0 = 10.
The question arises, what is the difference between the standard acoustics on the CX-5 between the first and second generation?
I would like to have HBC.
And I would like my front DRL works with the rear lights at the same time.
1. Your HBC lies in two lines:
706-01-01 6C80 9000 00.. &
720-04-19 9200 .... +
correct check sums in those two lines + correct check sum in 720-04-01 line
in case when You really possess the FSC-2g. camera
2. Nobody played with rear lights upto the moment (& no one plans in the nearest future vicinity). For that reason the best action for You would be to visit local Mazda electrician for hardware change, where he should:
a). replace your DRL & rear lights with LED lights;
b). connect the DRL lights with rear lights via a couple of additional power diods;
c). insert another couple of power diods into the original line leading to rear lights from rear lights relay;
d). add some switch when necessary to switch off the DRL/rear lights connection
@tirexzed : I just checked: The difference of CX-5 KE (1.Gen. 2012-2017) and KF (2.Gen. 2017+) without BOSE is the KF having tweeters as standard equipment. At the KE the tweeters come along with BOSE only.
(Additional info: The KF with BOSE has a subwoover in the trunk, the KE not.)
Please re-download latest version of the file (same version number). It has been fixed there.
Hello
Thank you for update.
I saw another error:
"Donate & Tutorial" tab column I row 17
is not "Paste data into IC sheet in A17 cell as Values"
but "Paste data into IC sheet in A15 cell as Values"
Tell me if I'm wrong.
Thank you
es:
Thank you so much. I'm going to test this.
I have led lights. So only need to join the rear light to a positive line because I want the lights ever. And as you say, a diode in the cable that usually has the power to avoid a return and turn on the front lights too. Thank you so much.
In the US or Canada it's possible to buy an MDARS cloud base subscription Here from 72hs to a year, IDK about the rest of the world, it also required expensive hardware, see VCM II link. Every year are adding more models, by 2022 the whole new model lineup will be using MDARS.
I'm sorry but I don't have some idea and I don't want to make a terrible operation. My car is a CX-3, data are different that other models, I understand
I found this value in my BCMM module. Is it correct? When I insert the values helping with the Excel file my checksum is different 6C 80 90 00 give me AB and not 00. Sure that I 'm doing something wrong.
720.04.19 go from 41 00 00 10 00 95 to 92 00 10 00 E9 (only change B0 from 41 to 92 and the checksum, is it correct?)
720.04.01 go from 2F 87 01 00 FF E2 to 2F DB 01 00 FF 36
When I change 41 to 92 I don't lost the rest of functions like LDWS, LAS or ALH that now I have, isn't it?
Looking the Excel in the section IC Mazda 2/CX3. It say
LDWS/LAS/HBC/ALH
b7b6b5b4 Value:
0010 - LDWS+HBC [FSC Gen 1]
1001 - LDWS+HBC [FSC Gen 2]
With 92 I have 1001, but If my camera would be a Gen 1 (I don't know), must I use the first value?
In the same value I can read:
M2/CX-3/MX-5 only!
b1b0 - Value:
00 - M3/M6/CX-5/CX-9;
01 - M2/CX-3/MX-5 (if no HBC);
10 - HBC+LDWS
With 92 the binary value is 01. Doesn't be 10 for my car? With this possibilities the values are 4A with Gen1 camera or 96 with Gen 2 camera. Sure that all of this is wrong but I can find a nice explanation of that, and I using the last Excel from this week that I assume that it has the best data on it.
If any body can confirm that I'm doing the things correctly and there aren't error in my operations I would be very thankful.
To be sure which camera & headlights You have expose the original data in your:
706-01-01 & 720-04-14 lines
706-01-01: 6C00 9000 000B >> checked with FSC Gen1 must be Right Hand (correct, UK car), AWD (correct) but I'n not sure if Gen1 or 2
checked with FSC Gen2 must be LWDS Enabled, HBC disabled (must I change this?), and LAS disabled although the car it has and I enabled it from setup screen
720-04-14: 0330 001 0073 >> >Xenon/LED+FS & Headlight leveling Auto type [BM] isn't it?
Sure that you have best data and so much experience to tell me if my car is Gen1 or Gen2 and wich values I must use
In that case my previous suggest for You in 720-04-19 9200 0010 00E6 was correct.
In your FSC-2g. the correct values should be 706-01-01 6C80 9000 008B with HBC only additional.
Those both lines are compared to your original configuration. It's up to You though when You like checking the other settings, but do not expect anything good from them.
And You can forget about LAS in CX-3. There's no CX-3 in the market with LAS available, at least because there's no EPS module existing for CX-3 which supports LAS
I'm sorry but they don't want.
with 9200... I have a warning of the LAS and another of HBC.
I decided to test another options:
  • The car had 0100 LDWS [FSC Gen 1]. Tested with 0101 LDWS+HBC. LDWS and SCBS-F Warning,
  • Tested with 0010 LDWS+HBC [FSC Gen 1]. SCBS-F Warning
  • Tested with 1100 LAS+HBC [FSC Gen 1/2] SCBS-F and LDWS warning,
I tested all of them with 706-01-01 changing the value on or off. Obviously every change I made I changed the 720-04-01 checksum.
I couldn't find any combination without warnings except the original value.
I don't know if the problem perhaps is caused with forscan. When I change a value I only have the option of "write all" and I haven't the option of write the value that I changed. When I click on write all button, forscan go to 100%, after until, 90%, after until 72% and them I receive an error of writting for not compatible contents. I read about this problem with the write all option, but I couldn't find other way to store the data.
After the error, I stopped the car, turn on, connect forscan and I checked that the value are stored. For example I change the value in 720-04-26 B2 from 10010001 to 10011001 that should change the rear camera form fixed 4 assist lines to dinamic 7 assist lines but there isn't any change in the screen when I inserrtt the rear speed.
Don't use the write all button, but use the write button down the page, around the last value.
Your 720-04-26 B2 change wont work, unless you have wired your rear camera.
