5581 - 5599 of 5599 Posts
The values which You can use already are:
720-04-19 B000 0010 0004
706-01-01 6C80 9000 72FD
706-01-02 84XX 0000 00YY
where XX - your original value there, YY - control sum automatically calculated in excel file when You type the B0=84 into the line.
Into 720-04-16 You'll have to type in:
720-04-16 X2XX XXXX XXYY or
720-04-16 X4XX XXXX XXYY, whichever would function correctly in your case,
where X are your original values in these cells & YY - excel calculated control sum for every case.
And change in the car 720-04-01 line also appropriate to every calculated case.
The chance to increase the SCBS reaction speed You can have only having replaced your original FSC with the new module which can do it. Your original FSC isn't able to do it ever!
Reactions: Eddemon
If i key in exactly what you said, does it change other thing or only to enable LAS?
I attach my original code for those lines you mention for your refering, Thank you so much.
706-01-01 after i type the checksum come out different from yours,
My checksum is:
720-01-01 6C80 9000 7217
Hello everyone !
I have a Mazda cx5 - 2018 2.0 WD, I want to do the project of switching to automatic dual-wheel mode (AWD), is it feasible? spare parts need to prepare? TCM module ... what to change? Any ideas?
Some news about LED Turn Lights.
At the moment the originally equipped models with LED turn lights are four: M6, CX-9, CX-8 & CX-4.
And there are three bits where they are enabled:
726-01-01 B1b4=1 - for M6 SD & CX-4,
726-01-02 B3b0=1 - for M6 WGN & CX-9,
7B7-01-03 B0b0=1
- for every M6 SD(only) equipped originally with the LED turn lights & always together with the enabled bit in 726-01-01 B1b4=1; in every CX-8 (VINs in my possession, but I have no idea whether they're equipped with LED turn lights); the lonely CX-4 certainly equipped with LED turn lights (VIN in my possession) with the enabled bit in 726-01-01 B1b4=1; & a couple of CX-9 (US market) together with enabled bit in 726-01-02 B3b0=1. BTW, this bit in 7B7-01-03 B0b0=1 is never found to be used in any other case.
The certain information I obtained is only about M6 & CX-9.
In M6 WGN & CX-9 the guaranteed LED turn lights are declared only forward (no idea whether the US market CX-9 with 7B7-01-03 B0b0=1 are equipped also with the rear LED turn lights).
The M6 SD LED turn lights area declared as the forward, as well as the rear.
One more important notice - the bits 726-01-01 B1b4=1 & 726-01-02 B3b0=1 are never met to be enabled the both at the same time.
Whoever likes to experiment with the LED turn lights in the other models - this is all the info necessary
Reactions: Eddemon and hellow
LED turn lights - means that instead of 4 yellow halogen lamps installed for the right & left turns indication forward & rear originally are already installed the LED lights. When the usual halogen lamp is busted there, You get on instrument panel the more frequent blinking of turn lights indication. The same happens when You exchange your halogen lamps with the LED lights.
Activation of those bits disables the checking of busted halogen lamps
Well thanks. So it isn't at all what I thought.
On some cars, when you turn your steering wheel to one side, the fog light on that side turns on. Idk about our Mazda.
That feature is present on VW for sure, but nobody reported to have that feature on Mazda
Sorry if i post this here instead of other threads, i cant find an answer on other threads, if anyone here has retrofit MRCC on mazda3 succeeded? May i know the hardware parts number i need please? Thank you!
Reactions: Eddemon
Today i accidentally enable a function called "Vehicle telemetry transfers" anyone know what is it for?
"So the police can find out how fast you were going at the time of the accident", just kidding !! I don't know the use of the data, I was able to transferred data to an SD card or USB, I've done it long time ago, don't remember exactly,
Enter 24 in the diagnostics menu. I couldn't make heads or tails of the data.
I think better to disable it. :giggle:
