5541 - 5560 of 5599 Posts
I installed shift paddles without having/retrofitting MRCC at a 2016 CX-5 KE and not had to change values in any module. Just had to add cables. Switching gears like in the photo above is possible.
And in our german cx-5 forum there were some people adding paddle shifters successfully to a cx-5 KF 2017/2018. Also without changing values in modules.
Regarding the "LED rear (or front) turn signal lights" feature which we have presently in two different bits of 726-01-01 & 726-01-02 lines.
The regularity I found for them indicates that:
726-01-01 B1b4=1 is used in M6 Sedan bodystyle since 2018 (and not every of them) & CX4 (China), meantime
726-01-02 B3b0=1 is used in M6 Wagon bodystyle & CX9.
These are the only models present in my DB collection with those bits enabled.
Whoever likes to test them in their cars keep in mind to apply these bits accordingly & in correspondence with Sedan - HB/WGN bodystyle
With a cruise like understood. Has come time for other useful functions.
I ask all who have a desire to connect to study.
Study SSU:
731-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B1 - it is (in BIN):
b7 - 0 or 1 = function is not known
b6 - 0 or 1 = function is not known
b5 - 0 or 1 = function is not known
b4 - 0 or 1 = 0 - I-Stop OFF, 1 - I-Stop ON (Tested on CX5)
b3 - 0 or 1 = function is not known
b2 - 0 or 1 = function is not known
b1 - 0 or 1 = function is not known
b0 - 0 or 1 = function is not known
B2 - configuration mode wireless control (step-by-step opening):
b7 - 0 or 1 = 0-W/O Advanced Keyless Entry; 1-W Advanced Keyless Entry
b4 - 0 or 1 = 1-W Unlock mode (2-step); 0-W/O Unlock mode (2-step)
b2 - 0 or 1 = 1-W Unlock mode (2-step); 0-W/O Unlock mode (2-step)
731-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
B0 - it is (in BIN):
731-01-03 B0 B1 B2 B3 (checksum) in HEX
B0 - wireless mode lock/unlock is ONLY displayed on monitor (for example it is possible to configure only display the "unlock Mode"(step-by-step opening) or together with "Lock when leaving car":
b6 - 0 or 1 = 1- NO visibility Lock when leaving car; 0 - visibility Lock when leaving car
b4 - 0 or 1 = 1-Visibility Unlock mode
b2 - 0 or 1 = 1-Visibility Unlock mode
Study RBCM:
7B7-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = 0 - no auto door lock or 1 - auto door lock (activates door lock function in RBCM)
b4 - 0 or 1 = function is not known
b3 - 0 or 1 = 0 - 1x blinker when doors close from remote control or 1 - no blinker when doors close from remote control
b1 - 0 or 1 = 0 - no blinker when doors open from remote control or 1 - 3x blinker when doors open from remote control (w/alarm system)
B4 - it is (in BIN):
b6 - 0 or 1 = 0 - OFF 1 - ON (ability to lock doors when Ignition ON) tested on CX5
b3 - 0 or 1 = 0 - OFF 1 - ON (ability to lock doors when doors open) tested on CX5
b1 - 0 or 1 = 0 - if engine work then not possible open boot or 1 - if engine work then possible to open boot (from button on boot)
7B7-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = no data on use
b6 - 0 or 1 = 0 - OFF Find My Car or 1 - ON Find My Car (Press lock button twice on remote controller, You will hear a shortly horn) tested on CX5
b5 - 0 or 1 = 0 - It does not allow to open the trunk in the Drive mode (D) or 1 - It allows you to open the trunk in the Drive mode (D) tested on CX5
b4 - 0 or 1 = no data on use
b3 - 0 or 1 = no data on use
b2 - 0 or 1 = no data on use
b1 - 0 or 1 = no data on use
b0 - 0 or 1 = no data on use
b6 - 0 or 1 = no data on use
b5 - 0 or 1 = 0 - no auto door lock or 1 - auto door lock (only for visible this function on CMU)
b3 - 0 or 1 = 0 - auto door lock or 1 - no auto door lock (only for visible this function on CMU)
7B7-01-03 B0 B1 B2 B3 B4(checksum) in HEX
b5 - 0 or 1 = Lighting Coming Home Light - ON
b4 - 0 or 1 = Lighting Coming Home Light - OFF
Study IC:
720-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B2 - it is (in BIN):
b6 - 0 or 1 = 0 - OFF Beeper driver seat belt; 1 - ON Beeper driver seat belt
b5 - 0 or 1 = 0 - OFF Beeper passenger seat belt; 1 - ON Beeper passenger seat belt
b4 - 0 or 1 = 0 - disable I-Stop; 1 - enable I-Stop (enable/disable button I-Stop and view logo "I-Stop" on Instrument Cluster)
720-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = 0 - Digital display Cruise control on IC; 1 - NO digital display Cruise control on IC
720-04-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B0:B1 - it is checksum for full configuration of car (IC)
720-04-14 B0 B1 B2 B3 B4 B5(checksum) in HEX
b5 - 0 or 1 = 1 - W ALS (Headlight Auto Leveling System); 0 - W/O ALS
b4 - 0 or 1 = 1 - and if b5 = 0, then AFS and ALS (Adaptive Front Lighting system) is OFF, if b5 = 1, then AFS and ALS is ON; 0 - and if b5 = 1 then only ALS is ON
720-04-23 B0 B1 B2 B3 B4 B5(checksum) in HEX
b6 - 0 or 1 = 1 - Cruise Control with LIM
b5 - 0 or 1 = 1 - Standard Cruise Control/MRCC
b4 - 0 or 1 = 1 - W/O Cruise Control/MRCC
720-04-24 B0 B1 B2 B3 B4 B5(checksum) in HEX
b5 - 0 or 1 = 1 - SCBS ON; 0 - SCBS OFF
b4 - 0 or 1 = 1 - SCBS OFF; 0 - SCBS ON
720-04-27 B0 B1 B2 B3 B4 B5(checksum) in HEX
b3 - 0 or 1 = 1 - REAR CAMERA with DYNAMIC ASSIST LINES (7 wires) ; 0 - REAR CAMERA with FIXED ASSIST LINES (4 wires)
for example:
edit string in configuration
7B7-01-03 0018 5400 2E
on
7B7-01-03 0018 9000 6A
adds features:
  • RAIN SENSING WIPER
  • AUTO HEADLIGHT ON
String 7B7-02-01 no need to change. This string enables/disables activated features, it can be done in media settings.
Connect to study.
Hello
On my 2018 Mazda CX5 Skyactive 2.2 150D. I'm looking for how, with "forscan" and "SkyActiv Mazda ASBuilt Configurations" Automatically activate the autohold function at each start because I like this funcion. I would also like to activate the parking brake as soon as the engine is switched off. I have already managed to permanently deactivate the i-stop with the posts of SkyActiv Mazda ASBuilt Configurations - FORScan forum. thank you for all aids.
Hello,
I would like to enable rear fog lights i my 124 spider "mx-5" from US but there is no RBCM only BCMM.
So do i only need to change the region in IC or there is something more that needs to be changed.
Hello,
You need switch to MS-CAN to access RBCM data. Please check if your cable has a MS/HS toggle switch, you can buy a forscan's official cable with MS/HS support on amazon OBDLink: OBDLink EX
Hello
I've seen an OBD plug-in module in Taobao that does exactly what you wish, enable AUTOHOLD when the car starts. I can't search anymore Taobao site, I haven't find a way without registering.
Hello,
First.
In reality the rear fog light is connected to ESU module, but the most chances are that it's activation is made in BCMM. The problem there is that all the necessary settings in that module are pre-programmed & cannot be accessed with Forscan. The only chance You have is to find the second hand module for european market & replace your original module with that one (keeping also in mind that for the rear fog light You'll need also one more additional switch position next to the forward fog lights). But,
Second.
In case when You have in your MX5 the Auto-door Lock available & functioning - there are 100% chances that You'll loose that function with european module. Could You kindly confirm the Auto-door Lock function is really working now in your car?
In any case there's always something You loose
First.
Second.
I have door locking after i start moving and unlocking after i turn off engine. I also have other functions that EU cars dont have like trunk open from button on dash board.
And i have installed the switch with rear fog light after this i got dtc in esu about wrong configuration.
Anyway i will just add new button and connect it to rear fog light wire, i need to find wiring diagram.
It could work only if You make the direct connection from the switch to the light.
Otherwise, if You'd like to follow the official diagram, where the switch is connected to SSU, light - to ESU, enabling the rear fog light & it's indication on the dashboard - in BCMM. There's no big problem to connect to the first two, but with BCMM You'll get busted.
Thanks also for your confirmation about ADL in US MX5, I suspected & was 99% sure of it, but had no confirmation.
This way, I assume also (and 99% sure of it) that US CX-3 cars also have the ADL feature functioning
I want connect directly to wire coming from ESU to light but i need to know where this wire is.
That is why i need wiring diagram from EU car, probably from Mazda 2 will be the same.
In the attached file the modules are:
ESU - Electric Supply Unit
Part number: D10A-675Z0-
Strategy : D10A-675Z2-A015/02
SSU - Start Stop Unit
Part number: BPP1-675S0-
Strategy : BKB2-675S1- -00
BCMM - Body Control Module
Part number: D10A-67560-
Strategy : D10A-67562-D
But do not wonder when the signal from ESU is not enabled (I understand that it should be there only when BCMM permits)
Reactions: ppawel
Hi! Do you need to connect the rear fogs exactly like in original? May be it is more easily to connect them directly to front fog lights, and switch them on together (rear and front) by one switcher you have?
Nikodim one last question for you, will i gain anything if i change region in IC from US to EU.
ALyapustin thanks for suggestion but i prefer to do it so i will have two independent lights.
Hello. I can not register block 3 in IC. Writes incompatible configuration. 720-03-01-042F is registered in the tidy, and in mine it was 720-03-01-012С. Tell me how to register block 3. Well, heated seats. If anyone knows. Thanks.
Hello everyone !
I have a Mazda cx5 Gen 2, made in 2019. I installed a radar system to activate MRCC / SBS, now I just want to go back to the original, when changing the configuration back to the original I got an error (like in the attached file). I fixed it, but it didn't work. I believe that someone may have encountered this. Any help is appreciated. Best regards !
278916
