5201 - 5220 of 5361 Posts
SCBS-R isn't related at all with FSC.
Imo you can activate LDWS, LAS, SCBS, HBC and TSR.
Change your 720.04.16.B0 with 82
Change your 720.04.19.B0 with C0
Don't forget to change the 720.04.01 checksum line
Change your 706.01.01 line with 6C.80.90.00.72.FD
706.01.02.B1 with 84 and .B4 with 00
@ NothinUnusual
First.
There's one misstyping in mr. hellow's post: instead of 706.01.02.B1 with 84 he really meant 706.01.02.B0=84.
Second.
For more correct recommendations regarding the 720-04-16 line we need You to expose some more IC lines:
720-04-08
720-04-10
720-04-14
720-04-15
Also, whether You possess ADD/HUD & Navi card in your CX-5. Otherwise activating DAA & TSR would be useless
Reactions: hellow
@ NothinUnusual
First.
Second.
720-04-08
720-04-10
720-04-14
720-04-15
Thank you so much for the quick reply. My car do not have HUD but I do have Navi card. Here are my other IC lines. I am not looking into TSR function but DAA is certainly helpful.
720-04-08 0039 0924 0099
720-04-10 9700 00BF 0192
720-04-14
0330 0001 0073
720-04-15 0000 BF04 3033
@ hellow
Wondering why "Change your 706.01.01 line with 6C.80.90.00.72.FD" it's 72FD? In the spreadsheet I don't see anything for block B4.
Change your 720.04.16.B0 with 82 - Anything to change in B2? I saw a comment about SCBS-R in the spreadsheet.
@ Nikodim
706.01.02.B0=84 seems correct based on what I saw in the spreadsheet.
OK. Your correct values in this line for HBC/LDWS/LAS/SCBS-R activation would be:
720-04-16 4200 4400 06xx with 720-04-19 C0.. naturally.
In 706-01-01 the value 72 (together with 84 in 706-01-02) activates LAS
TSR
& DAA will be obsolete due to lack of HUD. So, in your case 00 (activating TSR) in B4 of 706-01-02 wuold be obsolete also.
DAA displays it's info only over ADD/HUD, producing also the chime sound, but w/o HUD You wouldn't know what that sound means.
TSR also is useful only with ADD/HUD.
Good luck! And remember that LAS wouldn't function w/o LDWS activated & ON.
To everybody involved.
My latest investigation on 720-04-16 line leads to the fact that values in B0 b0,b1,b2,b3 heavily depend on the values in 720-04-08 & 720-04-10 lines.
The research still goes on, but that fact is revealed by major cases in CCC database collected
TSR
Yea I noticed that without HUD the DAA and TSR won't be useful anyway. Thanks for the clarification on 706-01-01 and 706-01-02.
Final value for FSC:
706-01-01 6C80 9000 72FD
706-01-02 843B 0000 10DF
Still a bit confused on IC. I'll try these suggestions. What I have now is these:
720.04.16 8200 4400 060D
720.04.19 C000 0010 0014
OR
720-04-16 4200 4400 060D
720-04-19 C000 0010 0014
OR
720-04-16 C200 4400 060D
EDIT: How to enable Advance SCBS? My car only has SCBS-F.
1. Your car really is already equipped with Advanced SCBS 534 (as I can see from your 720-04-08 & 720-04-10 lines, if I'm wrong correct me) in 720-04-24 line. The top advanced is only 535.
2. I confirm again, correct for your hardware would be 4200 4400
Uppss..
Sorry for double posting, it's due to my bad internet connection
All right. I think I am good to go. I am gonna try it out and see if it works. One more question, you mentioned something about "LAS wouldn't function w/o LDWS activated & ON." Is there any specific way to activate LDWS other than changing the numbers? Like plucking out the button cover and pressing it?
That way is also effective.
But first try to change your 706-02-01 line also to have there 6C80 9000 72FE &
706-02-02 8495
It may suffice to enable LDWS
706-02-02 8495
Oh that's interesting. Didn't know need to change the bottom part for 706-02-01 and 706-02-02.
706-02-01 6C80 9000 72FE - I got F6 in the spreadsheet instead of FE and I got 88 instead of 90. I think 90 or 88 should be okay since it's the distance warning setting for SCBS, at least according to the spreadsheet.
706-02-02 8495
@ Nikodim
It works perfectly without any DTC error codes. I can feel the LAS is working but there is no warning beeping sound from LWDS. I noticed the LAS kicks in at 70-80 kmph, is that the standard speed for LAS to work? Another thing is when I write the codes, drive the car around and check the code again, surprisingly 706-02-02 8495 changed to 706-02-02 4455.
Meanwhile for SCBS-R. I'll need to find some boxes to test it out.
EDIT: I wonder if my car supports ALH? hmm..
Glad that it's functioning.
8495 refers to the settings in LAS.
For LDWS try to change the reaction choices in CMU menu between vibration/rumble/whatsoever.
If it doesn't help that means You're missing the correct hardware in audio & that could have been the main reason why it wasn't enabled originally.
LDWS/LAS normally decrared to be working starting with 60 kmph
Reducing the speed to 40 kmph (for LDWS/LAS operation) found only in japan market vehicles equipped with FSC 1-gen. No similar precedents discovered for FSC 2-gen upto now
Can tell me more about Advanced-SCBS information, such as all parameters, thank you very much
Sorry about the mistake on 534/535 - that really belongs to A-BSM generations.
I personally do not possess A-SCBS & cannot tell very much about it. It has nothing special in configs (to be checked yet more thoroughly).
The SCBS generations are what I understand & can see from CCC configs database:
BF09200000211000 - LIDAR
BF09
100000311000 - LIDAR
BF09
410000400000 - SCBS (present in vehicles with FSC-2 gen.)
BF09210000500000 - Sorry for misleading (this one also is with FSC-2 gen. just some modification for japanese market)
It looks like I was wrong about A-SCBS in IC/FSC config. Sorry for misleading.
In reality & more thorough check it turned out that BF09210000500000 has been found only in japanese market vehicles. And could be only some kind of variation of BF09210000400000. But the both of them SCBS & A-SCBS nobody can distinguish by FSC/IC configuration.
But by value in the line 706-01-03 it's possible to determine to which model belong the second hand acquired FSC-2 gen. camera
Tested LDWS on other settings. Apparently only vibration works. Rumble and beep does not work. Oh well, it's better than nothing. Next I'll need to test SCBS-R and HBC.
Kinda hard to test if it's normal SCBS-F or the A-SCBS since it's kinda dangerous to test it out on the road. Maybe we need someone with latest model of the car with A-SCBS to share their codes.
I have a 2020 mazda 6 with LAS (unfortunately not the australian lane trace version), LDWS, ADD, but no TSR. What do I need to change in FSC and/or IC to activate TSR? I don't have a navi card in case that matters.
I can share parts of my car's FSC and/or IC configuration if it helps.
TSR can be activated easy, it's only in 706-01-02 B4 byte change to 00. But You wouldn't be able to see it (even in CMU menu) without the navi card inserted
I have a CX-3 with A-SCBS it works up to 80km/hr with pedestrians and cars. I think later on they added pedestrians at night + bicycle detection... maybe newer camera unit for that?
I have also LDWS and ALH from factory and I activated TSR, DAA and SCBS-R.
What info you need shared? I'm not sure if CX-3 works for you since it's a bit different that M3.
Let me know!
