5161 - 5180 of 5268 Posts
Hi, everybody. Thanks to the work you have done and the final result from hellow, I have on CX-5 2018 Supreme everything works. LDWS, LAS (LKA), Spotlight Levelling (ALF, ALS), HBC, SCBS-F,R. Without MRCC. Thank you guys so much! No errors on the devices. Just didn't check SCBS-R. The I-DM is also in the tape recorder, but does not evaluate driving. What might be the problem?
Mazda 3 2017 Sportsline
Hello Guys... i need Help
I have activated LDWS and LAS in FSC and IC.
the indicator lamp in the dashboard for LAS lights up continuously. there are no errors or anything.
Can anyone help me ?? I don't know what to do ...
Hopefully For Help
Best Regards
Marvin
Mazda 3 2018 Exclusive line
Hi, guys,
I have the same problem as Marvinbam.
HBC works fine but with LDWS/LAS the control light in the display is permanently on.
I got the values from Nikodim here:
706-01-01-6C80-9000-72FD
706-01-02-8400-0000-0094
720-04-19-C000-0010-0014
The original values are:
706-01-01-0000-9000-009F
706-01-02-0400-0000-0014
720-04-19-1000-0010-0064
Unfortunately, I do not get along so well with the Excel list.
Maybe someone can explain it to me via PN.
That would be really great!
Does your car comes from US or EUR?
In US this feature is always disabled and it needs to be activated by the user everytime, while in EUR the activation is saved and if it was enable before, it's after.
What's happen if you disable/enable LAS with the CMU?
My car is from EUR.
Then nothinf happens, every remains unchanged.
I had read in another forum some people in the IC Module have adapted line 16.
Could that be my problem?
Take a look at the picture with FSC PIDs in Marvinbam post regarding the LDWS switch. Do You have it the same, in OFF position?
Hi mymind and Marvinbam,
I had the same issue with the LDWS.
I guess you don't have the LDWS switch on the cluster switch, left of the steering wheel.
What you can do is to remove the blank LDWS button cap from the cluster switch and push the button on the circuit board.
The circuit board is the same for every car, but for the inactive functions they use blank buttons.
You can remove the faceplate from the cluster switch, then it is a bit easier to remove the blank button.
You need the cluster switch connected to the car and ignition ON when you press the button to activate LDWS.
This worked on my 2017 Mazda 3.
277497
277496
[QUOTE = "Drazick, post: 2490111, member: 187162"]
На английском, пожалуйста, это международный форум, поэтому английский язык должен использоваться как язык. Представьте, что каждый из нас использовал свой родной язык ...
Hi. Understand nothing.Insert the English text.
[QUOTE = "mymind, post: 2490122, member: 555318"]
Привет, ребята,
У меня та же проблема, что и у Марвинбама.
HBC работает нормально, но с LDWS / LAS постоянно горит контрольная лампочка на дисплее.
Я получил значения от Nikodim здесь:
Исходные значения:
К сожалению, я не очень хорошо лажу со списком Excel.
Может быть, кто-то может объяснить это мне через PN.
Это было бы действительно здорово!
[/ QUOTE]
Моя лампа также была включена. Пока я не изменил эти значения 720-04-14 B3 b1 = 1, b0 = 0; B4 b5 = 0
[QUOTE = "Denis10086, должность: 2490180, участник: 555134"]
Привет, ребята,
Марвинбама.
Исходные значения:
[/ QUOTE]
[/ QUOTE]
И не забудьте 720-04-01
@Denis10086 : Please write in english! Your posts are in russian or some other kyrillic language... the language of this forum is english. @arathol or another Moderator: Please do something ... we told him so often to use english, but he refuses to and keeps writing in russian - see his posts in this thread. If someone is not able to use english, he has to use a translator, as I have to use one for russian, if I write in a russian form.
Привет, ребята,
Марвинбама.
Исходные значения:
[/ QUOTE]
[/ QUOTE]
My lamp was also on. Until I changed these values 720-04-14 B3 b1 = 1, b0 = 0; B4 b5 = 0 [/ QUOTE] And don't forget 720-0401
