5141 - 5160 of 5268 Posts
Mazda 3 2018 Exclusive line
Hello,
nobody has any idea if I can activate ALH on my Car?
I have looked at the Excel file a little bit, but I don't really know what to make of it yet.
In which modules do I have to change which lines?
Only in FSC or also in IC?
It would be great if someone could help.
I can also specify values if desired.
Heya,
Maybe you can take a pic of your light and we'll be able to tell you, but imo I don't think so, you need the light hardware (kind of matrice led), I've never seen a car with the hardware without the function.
You cannot activate ALH without the ALH headlight hardware technology, otherwise You'll have only errors coming but ALH not working.
With other LED headlights it is impossible.
Which kind of LED headlights do You have? If You do not know then reveal us your 720-04-14 line
Would you please help me?
I suppose ESP and FSC should support LAS:
Check first whether You have available the LAS_CUR PID in your EPS module. Without it LAS can never be activated.
In FSC also the PID INH_LAS should be present
P.S.
Sorry, my bad internet didn't show me your screenshots.
The only what I can suggest is to check for DTCs related to LAS. Your settings look to be correct. Are You sure that LDWS functions properly?
I thought as much.
The values are: 720-04-14-0320-0001-0063
Actually You have ALS headlights. To activate ALH You need to change the both headlights to ALH hardware (they are expensive) + change also the controlling them module. With present hardware forget the activating
Expose your 706-01-01, 706-01-02 & 720-04-19 lines to find it out
706-01-01-0000-9000-009F
706-01-02-0400-0000-0014
720-04-19-1000-0010-0064
Thanks for your help!
Your chances:
706-01-01-6C80-9000-72FD
706-01-02-8400-0000-0094
720-04-19-C000-0010-0014
= HBC/LDWS/LAS
or
706-01-01-6C80-9000-008B
720-04-19-9200-0010-00E6
=HBC/LDWS (In case of problems with LAS due to the missing hardware).
+ Automatically re-calculated in excel file the line 720-04-01.(Do not forget it!)
HBC may not function if your vehicle is one of M2/CX-3/MX-5 (due to BCMM pre-programming)
Thanks a lot!
What are you meaning with this?
Must I change something by myself?
I have a Mazda 3 BN 2018 exclusive line.
I can give you my VIN if it helps.
Hi guys
really need your help with forscan auto door locking function when driving
i would like the vehicle to lock when driving over 20 km\h and unlock when shifting to Parking if possible
Its a facelift 2015 mazda 6 (no electric door locking button on drivers side)
my current hex codes are
7B7-01-01 0550 0006 A3BE
7B7-01-02 A504 0300 0875
also adding a screenshot if needed
thanks a bunch!!
277384
Hi guys
vin JMZGJ6238Z1208764
thanks a bunch!!
277426
After restart go to this menu and press RESET and the new menu would appear, select your preferred option.
277427
Thanks a lot!
Exactly what Nikodim told you. Use the excel file and enter all CCC data into IC, make your changes and take a note of 720-04-1 it would calculate the overall checksum for you, transfer this value to Forscan.
Is it possible to make headlights turn on whenever I open the car? (at night)
Leaving home only works when I put the headlights on "on" and doesn't work when its on "auto".
Mazda 6 2016 GT with LED headlights
It supposed to work with lights in AUTO, it works this way in my CX5 See Manual, I've looked at your asbuilt and you have those features by default but I remember reading in this forum that's the way it used to work in models before 2017 and I don't think they find an asbuilt setting to operate in AUTO, it must be a change in hardware or wiring, search forum.
