4841 - 4860 of 5075 Posts
Upss.. Late to reply. Discard it
Hi I have a problem and looking for a solution.
Car is Canada 2018 Mazda 3 HB Grand Touring with full LED lamps
Unfortunately druing the day both on OFF/AUTO i Get DRL function working like that:
- LED stripes + low beam
Anyone knows is it possible to do a forscan coding and get DRL working only LED stripe without low beam??
Regards
@selanking : As far as I know Auto Door Lock can be activated in the RBCM (7B7) and not in the SSU (731) module. See the XLS of SergSlim (see his signature) in the tab "Tutorial" for more details on which AS built has to be modified.
Edit: Hrmpf... sorry, rixm6 already answered the same earlier... I had a problem in updating the forum to the latest post.
do you have drl or parking lights on (drl is without rear lights)?
When it is bright outside on OFF/AUTO when I engage drive and start driving i get
led angel eyes on
low beam on
(dont know if rear light are on or not)
when it gets dark i get low beam indicator on the dash (but front lights were on before so nothing changes) - maybe this engages rear light or jsut does nothing
I would like to get DRL working with only angel eyes led on the front and nothing in the back
Thank you much for the input.
As I discovered further I found out the auto door lock is under 7B7 and managed to activate it.
I also disable the I-stop and Press remote lock button twice to activate short horn;
For the short horn, only works 2 times out of 10 attempts, any experience on this.
At my CX5 2016 I use the short horn rarely, bit it works every time. But I heard from an other Mazda6 driver the same as you experience... it does not work all the time.
2013 Mazda CX-5 2.0 2WD
Press remote button once, wait 2 seconds, press again (twice within 3 seconds), it works every time.
Marek Malik from Facebook found some bits in IC related to RHD/LHD, Body Style and Destination:
The LHD / RHD function changes the driver's position in all IC, RBCM, ABS modules etc.
88321386_634491797336810_5560951710140071936_n.jpg 87703340_2180018028767609_5645334228229947392_n.jpg 88183313_199392351299435_6500385461503000576_n.jpg 87514709_580588545919839_6048526349021216768_n.jpg 88241918_220690398975930_5788774578159353856_n.jpg
According to him:
720-04-11 B0
21 NA
31 EU
34 EU 4WD
41 UK
720-04-08 B3
I haven't added it to the file yet, as I'm not 100% positive which bits change what exactly, as we had A/C Eco in 720-04-11 B0 previously. So it might be a more complex change, rather than A/C only. As in case of Region in 720-01-01 B0.
Also, there are some findings of a person from Drive2.ru, which he refuses to share with community. But at least we know that it can be changed somewhere:
Road signs on IC
LAS default OFF
Hey all, hopefully I didn't miss it in my search of this thread but I'm trying to accomplish 3 things with my 2019 M6 GTR.
I have a Comma2 and there are features of the Mazda that I'd like to disable/modify to really let this system shine.
The first is the hands on sensor (torque input i assume) Id like to either disable the system, or change the timeout to infinity so that the steering wheel doesn't require a non commanded input while the Comma system is active.
The second is the LKAS system does not adjust below 28mph. This also makes it so the Comma cannot make minor adjustments in low speed traffic.
The third is the amount of torque the LKAS will apply, right now its pretty low and if the Comma is trying to make any turn more than a minor sweeping turn the car cannot keep up and I need to provide additional steering input to make it stay it's lane.
Thanks!
I went throught whole this thread and I haven't found how to wire the 7-wires reverse camera with dynamic trajectories to Mazda 3. I found a scheme posted by @CilianUnlock but I have no idea how to read it. I found couple of people here with some experience of this camera installation (@drazick @d3athgu1s3 @sliver). Could someone help me with the wiring? I have installed the sinosmart camera with static lines. I am not sure if the sinosmart camera use 3 or 4 wires. I suppose there are 4 wires (power, ground and video+ and video-). So I will use this wires with the new camera in the same way. This is easy.
275879
But how should I connect the extar 3 wires? I found this scheme but I cannot read the wire labels. There is MS CAN L, MS CAN H, External fr*, Mass.
275880
Could anyone help me?
hey guys, went through the whole topic but couldn't find any info related to auto fold when IGN OFF/Door Lock. I know recent Mazda cars have this functionality but I am not sure where to start to look for the setting.. Any tips ?
no, it is unavailable without 3rd hardware.
A: +12V
B: Nil
C: Video+
D: Ground
E: Video-
F: Shield Wire
G: MS CAN_H
H: MS CAN_L
