4801 - 4820 of 4882 Posts
The first script I uploaded above was not very advanced and would be something easy to do manually (as hellow said).
I created another one which I find much more useful. For this, you tell it what feature you are looking for (e.g. lkas), and then you give it a bunch of .AB files and tell it whether each one is for a car that has that feature or not. Then it goes through all the modules and compares the individual bits between the .AB files. It tries to find the bits that are consistently set to the same value for all cars with that feature, but are different for cars without that feature. In the end it prints out the bits it thinks are related to that feature as 1 and the others that it thinks are not related as 0.
With python scripts you normally need to install python and run it through the command prompt. Since not everyone is familiar with that I made this one an .exe that you can use.
Let me know if it is useful and if you have any suggestions.
EDIT: See post below for updated version. This one contains a bug that causes it to crash when two AB files have a different length of AB data.
I got the message from Win10, that I do not have access to the *.exe and AVIRA (Antivirus) quarantined the *.exe:
It is a false positive. Probably due to the program I used to convert the python file to an exe. Try the new version attached. It is built using a slightly older version of the program I used before since it seems to be detected less by anti-virus softwares. I assure you it doesn't have any viruses in it haha.
(Also it contains a bug fix that caused the program to crash in some cases.)
Hi guys! I have Mazda 6 2019 with SCBS-F and I can't enable LKA and LDWS. I have in menu LKA but it doesn't work at all. Btw I managed to enable HBC. That's what I have changed:
IC:
720-04-16-8200-4480-078E
720-04-19-C000-0010-0014
FSC:
;Block 1
706-01-01-6C80-9000-72FD
706-01-02-8420-0000-00B4
706-01-03-2021-0000-0052
706-01-04-0000-12
;Block 2
706-02-01-6C80-8800-72F6
706-02-02-8495
IC:
FSC:
;Block 1
706-01-04-0000-12
;Block 2
706-02-02-8495
The EPS module in your car likely does not support LKA CAN messages since your car didn't come with that feature, so most likely you're not going to be able to enable LKA. Although, you may be able to enable LDWS tho with audio alert only (no vibration).
You can try these, they are based on values for my car (which is a 2018 Mazda 6). You might get DTCs since I also have LKA.
FSC:
706-01-02 84A8-0000-104C
706-02-02 90A1
IC:
720-04-16 C400-0000-0005
FSC:
706-02-02 90A1
IC:
Thank you! I will try it tomorrow. Btw I can see in EPS that I have LAS_CUR. I believe there is a chance to enable it
EPS:
275556
FSC:
275555
EPS:
FSC:
Oh ok, that's great. Disregard what I said earlier, it should work.
Some additional notes before you try what I posted above:
  • I also just noticed that I also have 706-02-02 8495 sometimes. I think that value is related to your current LKA settings, so you don't have to change that.
  • If your car has TSR, then use 706-01-02 84A8-0000-205C instead.
  • If your car has parking sensors or SCBS-R, then modify the 720-04-16 I posted above based on the spreadsheet by SergSlim. (just B2). (You might have to also modify it if you have DAA).
Let me know how it goes. If it doesn't work, please share your original asbuilt data for IC/FSC.
Could you also please do me a favor since you seem to have the LKA menu. Can you compare how your IC and FSC data change when you change the Intervention Timing setting in the LKA menu.
Sure, so the first one is for early intervention and the second one for late:
275572
I don't understand what I did wrong but LKA didn't work...When my windscreen was dirty there were two indications on the panel like HBC and SCBS-F was orange but there wasn't LKA. I attached my initial config
you need to add the SMD LED
Hello, I finally found a switch and I added the LDWS button on mine.
Button works as expected but the SMD Led I soldered from the other board does not light up.
I tried in every possible way, but no light.
I saw that some resistors are soldered where the initial button are, maybe I need to add a resistor for this Led to work? It doesn’t make sense.
Anyone have a picture of the circuit board from a BAMG66170A switch? To see what resistor is near the LDWS button switch
Immortal
fsc asbuilt 2019 Mazda6 with LKA
;Block 1
706G1G16C80900072FD
706G1G284A80000205C
706G1G3202100000052
706G1G4000012
;Block 2
706G2G16C80900072FE
706G2G28495
IC
720G4H044002480062F
720G4H3C00000100014
It might happen that in case of ALH in your system the line:
720-04-19 B000 0010 ... (720G4H3B0000010 ...)
could help You
These are my suggestions:
IC:
720-04-16 8400 2480 066F
720-04-19 B000 0010 0004
FSC:
706-01-02 84A8 0000 306C
706-02-01 4C80 9000 72DE
706-02-02 8495
Let me how it goes.
Thank you for the data!
I tried changed my 706-02-02 to 4455, which I got from comparing the binary data for early and late, although it did not work. I still have no early mode LKAS, although there are no DTCs and everything still works as though I haven't changed anything. The only difference in our FSC data is the '3' in 706-01-02, which I will try later. If someone else who actually has LKAS running could compare there asbuilt between early and late I would really appreciate it :).
If you have the time could you also compare the asbuilt data for lkas sensitivity. I think it also alters 706-02-02, but in North America we only have Low and High, while you guys also have Medium. I noticed it used up 3 bits and that was weird since there are only 2-3 options. Thanks!
Hi!
My 2017 mazda 3 implemented autohold, but new problems appeared!
I used 2017 CX-5 ABS,The wheel speed is different from the actual speed!
Does anyone know how to change the calculation of abs?
cx-5 225 55 19
mazda 3 215 45 18
275628
Hi!
cx-5 225 55 19
mazda 3 215 45 18
Hi, I suppose you mean that the speed on IC does not match with actual car speed.
If so, with Sergslim xls you can correct the cluster speed to match your actual speed. This is performed on IC via as built config.
Enviado desde mi Redmi 6 Pro mediante Tapatalk
I am wondering. Anyone test/use forscan on gen 4 Mazda 3? TSR for USA model is disable and I kinda want to know if 4th gen owner can unlock it by using forscan.
