4701 - 4720 of 4757 Posts
Imo your car could have LDWS but not LAS
My car has LDWS from factory, was in the MZD menu under Safety, I activated LAS with Forscan along with HBC and DAA, but I have that error for LAS
I don't understand exactly what you are saying, are you saying that it's not possible to have LDWS and LAS together?
Thay are both in the MZD (CMU) menu now and.
No I mean, imo you haven't the hardware for LAS.
I didn't know you had LDWS from factory.
Ofc you can have LDWS + LAS together.
[QUOTE = "rixm6, publicación: 2437183, miembro: 277922"]
puntería dinámica
Es necesario conducir el vehículo durante un total de 5 a 10 minutos en las siguientes condiciones para completar el apuntado a mitad de la conducción (apuntado dinámico). Sin embargo, conducir el vehículo mientras se cumplen las condiciones no tiene que ser continuo.
  • Conduzca el vehículo a una velocidad de 40 km / h {25 mph} o más
  • Conduzca el vehículo en una carretera recta (carretera con un radio de giro de 300 m {984 ft 3 in} o más)
  • Conduzca el vehículo en una carretera con marcadores de carril y estructuras (edificios y señales)
  • Conduzca el vehículo en una carretera con una superficie nivelada (no en carreteras irregulares o inclinadas)
[/CITAR]
C
dynamic aiming -
Driving the vehicle for a total of 5 to 10 min under the following conditions is necessary to complete mid-drive aiming (dynamic aiming). However, driving the vehicle while matching the conditions does not have to be continuous.
― Drive the vehicle at a vehicle speed of 40 km/h {25 mph} or more
― Drive the vehicle on a straight road (road with a turning radius of 300 m {984 ft 3 in} or more)
― Drive the vehicle on a road with lane markers and structures (buildings and signs)
― Drive the vehicle on a road with a level surface (not rough or inclined roads)
Can I do it with forscan?
dynamic aiming -
So, I have finally stopped LAS and keeping only LDWS, this way I get rid of the DTC for steering wheel control module ( I don't think I have the Viration hardware).
I also saw LDWS in action few times, but I am not sure if it operates correctly.
I don't have a physical button to ON/OFF the LDWS and in MZD it has only setting not ON/OFF, but it seems it is active.
When it beeps or rumble the indicator light with car lanes flashes in IC in amber color and from what I read, when it;s On it should remain ON in amber color and when it is in action it flashes in green color. I have never saw green color on it, only amber flashing.
I am am puzzled that I don't have ON/OFF setting in MZD and also not sure it the system works fully 100% correct, as XLS file doesn't have clear/tested/setting for LDWS, they are all in yellow and with question marks, my settings are on for all the cells in yellow regarding LDWS.
Anyone else has some experience with Forscan activated LDWS and it works correctly?
Can anyone tell me please what address 720-04-11 B0 represents? I'm comparing 3 identical CX-5's. 2 of them have "24" on B0 and the other "21" at B0.
@shox75 : If we would know that, it would be written in the XLS of SergSlim, but it is not mentioned there, what the according two different bits might be:
720-04-11 B0 = 21 means b2=0 and b1=1
720-04-11 B0 = 24 means b2=1 and b0=0
Other cars with VINs to compare them, you can find via www.otomoto.pl (use Google Chrome`s translation) & these you can compare with your car (e.g. using the polish pricelist).
Or perhaps you can just test it? Dont forget the new checksum of 720-04-01 and do a backup before.
@freestyler : I retrofitted a FSC Gen.1 in my CX-5 KE 2016 and activated LDWS (LAS was not possible, as I did not find the fitting values for IC/FSC Gen.1). See this post. For a better understanding of LDWS see this post. And perhaps the value findings of dekor238 might help you, which can be found here.
@freestyler on my M3 2017 (2nd gen FSC w/o LDWS/LAS from factory) I successfully activated it w/o the physical button. The IC light is off and it's flashing in amber when I cross a line.
I know the LDWS/LAS is activated because on my HUD there are 2 lines when the FSC see the lines.
The only constraints is I can't deactivate LDWS (because of the missing button), only LAS on Mzd.
Thanks hellow and Tristan, from what I see My LDWS works good but I cannot deactivate it without physical button, I was afraid that it wasn’t started because the lack of the button.
I will try to find the buttons and maybe retrofit them, maybe they are not that expensive.
Also, do I need to perform some static/dynamic aiming for LDWS to work properly? I read something about that, I’m asking because my feeling is that LDWS, just activated doesn’t perfomes very well, only warns me from time to time and only when I am past the continous line on the road, maybe it needs to “learn” more, to say so:)
also hellow,do you mind sharing your FSC config and IC for line 16 and 19?
Thank you!
Maybe tell us your data and we can tell you what could be wrong.
Here are mine :
IC
0720041682004400070E
07200419C00000100014
FSC
070601016C80900072FD
07060102840000000094
07060103000000000011
07060104000012
070602016C80900072FE
070602020011
Thank you, hellow,
My setting are:
FSC:
Block 1
706G1G1 6C809000008B
706G1G2 04180000103C
706G1G3 202000000051
706G1G4 000012
;Block 2
706G2G1 4C80900072DE
706G2G2 0011
IC:
720041682004400070E
7200419C00000100014
hese settings are for LDWS + HBC only,
I have tried your combination and also some others that includes LAS, with everyone of them I have the same DTC:
Code: U0131:00-48 - Lost Communication With Power Steering Control Module A
My gues, as stated in some post above, is that I don't have the physical hardware for vibration and I cannot get rid of this DTC without installing the hardware, also I have a feeling that when I have this DTC, the LAS/LDWS don't work at all, like because of this DTC the system shuts it off completely.
Vibration works for you after activating LDWS/LAS? or do you have this DTC?
Yes it works well.
Imo you should check your
706G2G2 0011
Atm mine is 070602028495 (the one I told you earlier is my factory value sprry)
You can also try 070602024455
You're wrong the setting you're telling is for LDWS + LAS + HBC.
Can you tell us what's your understanding of LDWS and LAS? Maybe we(you) don't have the same definition.
Well, from my experience the line 7060202 XXXX is some kind of checksum, Forscan changes it, or the car changes it.
I had 4455 there, I also had some other values but was making no difference.
LDWS means under MZD - Safety I have only Lane Departure Warning System ( this is with my configuration) and with yours and whenever I activate LAS ( according to XLS) I don't have Lane Departure Warning System in MZD Menu, I only have LAS, Lane Keep-Assist which it include LDWS
Can you share your IC line 14 in B4, that's starting with 7200414?
I read somewhere that for some people changing this line had effect, for other it didn;t, maybe I should change something in Line 14 of block 4 also
