4621 - 4640 of 5078 Posts
Hello
My CX5 (KE) 2016 :
720-04-14 B0: Nothing
720-04-14 B1: b6=0
(1=ALH; 0=No ALH)
720-04-14 B1: b5b4=11 where
01 - ALS OFF, AFS OFF
10 - ALS ON, AFS OFF
11 - ALS ON, AFS ON
720-04-14 B3: b1b0=10
(Headlight Levelling: b1b0 - Value [model]:
00 - Manual Type
01 - Auto Type [BM]
10 - Auto Type [BN])
I have genuine front led with AFLS (AFS module + Swivel actuator)
00 - Manual Type
01 - Auto Type [BM]
I'd say it's disputable. My M3 2017 has BM in VIN numbering, but is marked as Carline BN in spare parts catalogues.
Non the less it has 01 in 720-04-14 B3: b1b0 & really has ALH with HBC present originally in menu & IC panel, which is working
Hello
What is the difference between BM and BN
I note that you have ALH with HBC because you have a FSC module. My CX-5 have not a FSC....
On my CX5 (KE) 2016, the glow beams are directed with the swivel actuator which is coupled to the direction and the vehicule speed (under 10km/h the glow beams are fixed)
I have a mazda cx5 2018 with ALH but doesnt have AFS, anyone can help me how to enable this function. Thank you so much
Here in Germany all ALH equipped CX-5 also have the AFS module included. I guess thats everywhere for every model (also Mazda3 with ALH) the same. But the swivel to the right/left is not necessary at ALH because of the sectional switch of the LEDs at ALH. I understood, that a movement of the single main LED (as used at AFS) is not necessary anymore, as the ALH has sectional activated LEDs, which might look like as if AFS is in action. Here a video of ALH in action & here a picture of the ALH sectional LEDs. The best video is this at 1:04 to show ALH in a curve.
thanks for your help bro ;)
Actually I didn't know the difference between BM & BN before I've found in https://partsouq.com/en/catalog/genuine/vehicle?c=Mazda&ssd=$*KwHm0sPb7Jme4J6Agb_14L6qio2T4u3g4fPl7ZSzrKS955Llv7IAAAAAjfSCYg$&vid=1926648007&q= the string "Carline BN". Until that time I've considered to have M3 BM (according to my VIN). If someone knows better - try to teach us
274526
Mazda EPC ^
Basically, BN are all restyled models with the new steering wheel.
However, early restyled models had less changes comparing to the later models, and they have BM written in VIN code, but still they are considered as BN in EPC.
Mazda EPC ^
Hello
Where did you find this table
I would like to see the same for CX5 to know if my CX-5 (KE) 2016 is BM or BN
Thank you
Your CX-5 2016 is neither BM nor BN (both internal codes for Mazda3 only), it is a KE and the newer version is the CX-5 II (started at 2017) with the internal code KF (instead of KE).
CX-5 I, KE, 2012/2013 - 2017
CX-5 II, KF, 2017 - present (2019)
Hello
I ask this to check in 720-04-14 B3b1b0 if the array is right ...
00 - Manual Type
01 - Auto Type [BM]
10 - Auto Type [BN]
The XLS is mainly for Mazda3. I also have a CX-5 2016 (as you) - with AFS + LED (no ALH) - and my setting is b1=1 and b0=0 - so "10 - Auto Type [BN]" is also valid for the CX-5 2016 with AFS + LED (no ALH).
Edited: b0= is 0 ! ( "=1"was a typo before), so its 10 = BN setting for my CX5
Sorry, my b0 is also 0. It was a typo before. That means that your CX-5 KE has the same setting/value for headlight leveling as mine and the Mazda3 BN (and probably some other models, which are not known by now).
Anyone on here with a manual (maybe auto too idk) transmission and their instrumemt cluster suggests what gear to be into? (4>6) kind of thing.
If so, can I see your instrument cluster asbuilt?
Thanks
