4541 - 4560 of 4812 Posts
Upd: btw EU region didn't remove LDW-off icon.
I had problems in understanding the LDWS-off icon. Here is how its working for me after retrofitting a FSC Gen.1 (LDWS + HBC) to my CX-5 2016. Perhaps this explanation helps you?
1. LDWS inactive. No lines aside the car icon. LDWS off icon also above 65 km/h.
2. LDWS ready, but below 65 km/h not active. But in general active. LDWS off icon if below 65 km/h. Not filled lines aside the car icon. I could only activate this ready status via pushing the LDWS button at the new/changed cluster switch left of the steering wheel.
3. LDWS active, when above 65 km/h. Lines are filled, when lines are recognized by the FSC and the LDWS icon is not "off" anymore.
I also had problems in understanding the LDWS-off icon. Here is how its working for me after retrofitting the FSC (LDWS + HBC). Perhaps this explanation helps you?
Thanks, will try tomorrow on the highway. Btw which headlight modules do you have?
Just as info: Technically it should be possible to activate HBC without AFS. At least for the CX-5 2014 it was possible to choose HBC as option without AFS in the pricelist. In reality probably no one did that, as most people would have bought the tech option package (AFS+HBC).
@tuzkyxy : Most probably your modules (BHS2-67Y80B and BHS2-67Y90B) are RVM only and not BSM. According to ilcats.ru here, your modules are from a M3 before 2014-11. BSM was introduced for the M3 between 2016-06 and 2016-12 at least here in Germany according to our price lists.
Differences I found:
  • RVM: Starts at 60 km/h
  • BSM: Starts at 30 km/h and includes RCTA in the module
My Mz3 2015 has RVM, it starts working at 30 km/h but I don't have RCTA... So, can I enable RCTA?
Enviado desde mi Redmi Note 7 mediante Tapatalk
Technically it might work, but as far as I know, no one knows so far which values have to be changed for the activation of RCTA. Would be great if you`ll find out via comparing different AS Builts.
My Mazda 3 BM has HBC and Bi-Xenon
Are you sure, that you do not have AFS? Because in Germany e.g. HBC was only available at a 2015 Mazda3 in combination with AFS in a package together with HBC. Would be great, if other regions allowed other combinations.
Hi there, i have cx5-2018, after trying to enable SBCS, i got the menu entry of smart brake city support in CMU, but there are 2 warning lamp appeared too: ABS and DSC/TSC light. What should I do to remove those warning lamp?
274057
I have just bought a speedometer(IC) of (?-2016) mazda 3.BM. Japan parts
the speed pointer can rotation fot test itself after electrified .but in many cars it couldn`t
could anyone knows how to active it?
the 4th pic is a .gif.
One more question is that : Does RVM moudle and BSM moudle has the same circuit wiring?
I have got a set of wires with the moudle(BHS2-67Y80B/90B) .I found that it`s diffent from the manual of <2014 Mazda 3 Service Manual v1.3 .pdf> 0922-6 BSM
So I put it into my car. and change 720-04-19 B3 b5 =1 for activate RVM on IC also 720-04-01 B0B1 . then it lights up and get DTCs (I forgot to take photos, sorry) .So it doesn`t work I think
I would guess that RVM and BSM do not have the same wiring at the Mazda 3. At least the wiring of RVM @ CX-5 2012 and BSM @ CX-5 2018 are different. See wiring diagrams:
- RVM @ CX-5 2012:
- BSM @ CX-5 2018:
Have you considered RBCM 7B7-01-01 B3 b1? All other settings of SCBS seem to be in IC module (SCBS and SCBS-R).
Yesterday I did some changes in Excel file (6.19):
Updated CCC Converter tab to explain on how get the website working for those without such experience.
Also hid some placeholders for Mazda 2/CX-3 not to disturb owners of majority of other cars.
And redid a bit description of Brakes value in RBCM.
Also started to compile a table with links to cells for given functions on Donate & Tutorial tab. Please take a look at it and give your feedback.
Could you please share your IC and FSC
sure. this is an old Forscan format, cuz it's my backup. VIN was removed.
IC:
Code:
;Block 1
7200101A3206B2680FD
72001027900B2F7105C
720010300000000002B
720010400000000002C
720010500000000002D
720010600000000002E
720010700002F
;Block 2
7200201BAF7100000EB
;Block 3
7200301012C
;Block 4
720040119740080FF38
7200402FFFFFFC100EB
7200403000000000000
7200404000000000000
7200405000000000000
7200406000000000000
72004070000C1033860
7200408001B099400EB
7200409C10400000700
7200410B50000BF01B0
720041131000000006D
720041200BF0220001E
720041300000013BF10
7200414032000010063
72004150000BF043033
72004168000240000E5
7200417BF0510000016
7200418000000BF0608
7200419200000200084
720042000BF07000011
720042100100000BF1B
7200422082120010097
72004230000BF092036
720042400002000006F
7200425BF101000002F
7200426100000BF1131
72004272003800000F5
72004280053
FSC:
Code:
;Block 1
70601012330513000E3
70601022C81000000BD
7060103000000000011
7060104000012
;Block 2
70602012C81000000BD
7060202000000000011
7060203000012
pretty sure :) they have Auto Leveling, but not AFS. and I don't have any AFS settings in CMU :(. in any case my module is:
AFS/ALM - Adaptive Front Lighting System / Auto Leveling Module
Part number: B45B-51225-00
