1 - 1 of 1 Posts
Stopped being able to connect to headunit process
I cleared my *bz2 log files. I started up a hotspot on my phone and connect my laptop and MZD to it and ssh's from my laptop to the headunit, I could never get the USB drive to run the install process, ever.
So I deleted things manually (AA folders, etc., using ssh).
/tmp/root # df
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 489408 411608 77800 84% /
none 8192 1172 7020 14% /dev
/dev/ffx01p1 489408 411608 77800 84% /
none 131072 4524 126548 3% /tmp
/dev/ffx01p4 314496 3668 310828 1% /tmp/mnt/data
/dev/mmcblk0p2 585976 58133 527843 10% /tmp/mnt/data_persist
/dev/mtdblock5 128 128 0 100% /config-mfg
/dev/sda1 7753728 5676736 2076992 73% /tmp/mnt/sd_nav
/dev/sdb1 978880 61208 917672 6% /tmp/mnt/sdb1
/dev/mmcblk0p1 3256064 797142 2458922 24% /tmp/mnt/resources
/tmp/root #
My space looks good but I can't "install" again. It doesn't seem to matter if the USB drive is in there 2 or 20 minutes. Twice I saw the AIO screen comes up but after the gui dialogue there was nothing.
Is there a scrip or tool to remove everything from SSH so I can start over?
1 - 1 of 1 Posts
