Although they have done what they should, that's still very nice of them.I have the same vehicle and my infotainment unit bricked to a blank black screen with only the previous radio station playing in the background.
I called the Mazda Connect support number and theyre aware that this is an issue and replaced it for me at no cost. I recommend doing the same.
here you goI am trying to find the password for the .up files. But somehow it eludes me. I searched the whole day and can't find anything.
Can someone please send me the password via pm or give a hint how to extract the files needed? (As described by yml)
5X/9vAVhovyU2ygK
THANK YOU!here you go
this is how the whole assembly looked in my case:
Thank for great infomation to recover CMU!I put the 56.00.513B image that I flashed here: drive.google.com/file/d/0B-PklWDYOggeMW9UVHdwNWNrbXM
The "bad" image I saved from my bricked ROM is here: drive.google.com/file/d/0B-PklWDYOggeM1VDVHpYMy16U28
Thank for your useful information, i'll try your suggestion to recover my CMU!anhnga, on this picture you can see that the CH341APro board has a black 16-pin panel on it, but only 8 pins are used in our case (the rest are for a different chip type). When you buy CH341APro, the package includes also a little additional PCB (the green one, with numbers etc.) and 8 little wires you solder on this PCB exactly as you see on the picture. The other 8 holes remain unused. You will insert the PCB with these wires into the black panel.
Then, you solder either the SOIC-16 itself, or the test clip wires on this green board. If you use the test clip, simply solder the corresponding wires, I think you can easily trace which wire corresponds to which SOIC-16 pin.
upd: OK, I see you want to know how the pins are connected on the PCB to insert the clip wires directly to the panel. This is how the pins are connected on the green PCB. The first column is the number on the PCB (so that 1 and 8 are in the middle of the black panel, 4 and 5 are at the edge). The second column is the pin number of SOIC-16.
1 - 7
2 - 8
3 - 9
4 - 10
5 - 15
6 - 16
7 - 1
8 - 2
Can you tell me, which file you used to flash the chip, which flasher program to flash that chip?I flashed the chip (it took two extra times to flash it before I figured out I have to erase it first, otherwise there's nobody to turn zero bits into ones). My friend soldered the chip to its place on PCB, I connected everything and the system booted as if nothing had happened.
Thank you for the excellent work, but could not you paint everything step by step (sorry for bad English, I'm from Russia, and I do not know English well).anhnga, on this picture you can see that the CH341APro board has a black 16-pin panel on it, but only 8 pins are used in our case (the rest are for a different chip type). When you buy CH341APro, the package includes also a little additional PCB (the green one, with numbers etc.) and 8 little wires you solder on this PCB exactly as you see on the picture. The other 8 holes remain unused. You will insert the PCB with these wires into the black panel.
1 - 7
2 - 8
3 - 9
4 - 10
5 - 15
6 - 16
7 - 1
8 - 2
HELLO,as i said your CMU not hard brick.. you are lucky that failsafe was went 100% if wifi dont come up then use putty as seriel as vic_ over this post russian tweek.
yours problem 99,9% the screen only not the CMU, take it apart and check th conector between LCD and the unit.My situation may ... but i can use script from usb to turn on wifi AP,but i dont know what to do next?i find in many post but still can't find the right for me.Help me pls!Thanks alot
I tried to search for this specific answer but didn't see it. I was beginning to have touch screen problems on my 2014 Mazda 3 (out of warranty) with bose/navi/infotainment etc so I was going to try a firmware update. I was on 55.00.650 and I successfully installed the failsafe part of the 59.00.411. When I got back into the diag menu the touchscreen was dead so I couldn't enter "99" to begin the second part of the install. Instead of using the commander knob to scroll to 99 I stupidly held mute+nav to do a reset and the screen went black and never came back on. No Mazda logo or any backlight whatsoever, just radio playing in background.
I don't believe the bootloop recovery threads will help because it wasn't after a file modification that this happened, although I have had the touchscreen speed limiter and background pic modified for about 6 months with no issue. My display shows nothing at all. Please advise me if you think I can actually recover using one of these threads.
My question is I've found some replacement CMU's which match my part number (BHP1669C0 K2352) on ebay for a reasonable price used. With these used units, can I install this in my car and use it or will be locked by anti-theft code or some such thing? I just want to know if I'll be able to use one of these used units or will I need to buy a new OEM unit to fix this issue?
I'm just trying to do this fix myself without paying the dealer if possible!
Thanks for any advice!
