When it runs does it make a noise? If it does it is probably a bearing and the fan motor needs to be replaced. Check for leaves in the motor. If it doesn't make a noise when running it is probably an electronic problem. Check the fuse to make sure it is not loose. If you have a volt meter check to see if the motor is getting current. Lost resort, take it to a qualified mechanic.Good luck.
