81 - 100 of 319 Posts
Sorry for the delay, funny, this is the 3rd or 4th failed EU version 56.00.513B I've seen, please try this file I'm attaching it should work, rename to *.bin. Difference with original are some stored settings in NV and also version name somehow it was renamed to "reinstall.up" maybe the user run that first instead of failsafe.up.
No worries - no one is in a hurry. Thanks for checking and sending me the file. I erased the chip (+checked via blank-button), opened your file, wrote it to the chip, veryfied it, hit exit, disconnected the clip, put the cmu board in the housing and connected the cmu to my bench setup (verified working with cx-5 cmu`s so far, wiring is not different to mx5 or m3 CMUs). But nothing happened, when I powered it. Just a black screen. Did the procedure incl. writing to the chip again, same result. Then I changed in your file at line 10000 the first values from FF to 00, but still nothing to see at the display. Then I connected a cx5-CMU and the display worked. Might it be, that the CX-5 display (build in dashboard, instead of on top of dashboard like at M3/MX-5/Miata) is not working with other CMUs? Or do I have to run the CMU in the car for some reason? My bench has a CX-5 display, old usb hub and a commander knob.
Your assumption, that the user of this CMU did something wrong might be partially right and wrong: The user does not know how to perform firmware updates and had the car at the dealership (Sept. 2020). They told him, that the latest firmware has been installed by them (so if something went wrong while installation, it was the fault of the dealership). And after 1-2 weeks after the said-to-be-update-by-dealership (not checked by user/customer) the display went black sometimes and then completely. Then a new CMU was sold/installed.
Or its not the SPI NOR chip, which lead to the non working CMU, but some other chip/condensator/cold soldering connection. But how to check all the connections at the CMU board? I have a multimeter and know how to use it, but these are so many connections.
@craz @Tristan-cx5 Maybe some of you guys will be able to help me. I've found what version was inside of dead CMU - it was 33.00.100A EU N. I've tried this method and screen worked for a moment to let me try install firmware again. I've recorded a video. It last around 2 mins and please watch it till the end. I've started on purpose with 59.00.502 EU N and 70.00.100A and 3rd pendrive had the correct firmware 33.00.100A. Then something strange happned and you can see that on the video - for 1 or 2 sec I've seen installation progress bar and then out of the blue information that installation was successfull which is not possible to happen that quickly. When I restarted CMU there is only Mazda logo and nothing more.
Link to youtube video ->
Performed method:
1. I've done it with 6x test clips and rapberry pi and I've sent all command described here
2 I've used SOC16 Clip and CH341A programmer and after that I've changed FF to 00 in address 10000.
Questions:
1. Any idea how to deal with this impossibly fast installtion which leads to constant Mazda logo view?
2. After 1st and 2nd method I've received the same effect as you can see on the video. So my question is if the 1st and 2nd method are the same thing just different approach and required tools?
279987
Performed method:
Questions:
Yes, you are right, 1st and 2nd menthod are the same... but 2nd menthod is more quickly than 1st do...
You get quick install firmware to that screen because you using the backup .bin of the original version firmware preinstall by factory, you may be can try use other CMU working with firmware install by user and then do backup this CMU to .bin file, after that use this .bin file to flash to bricked CMU and try to reinstall new firmware....
In post #79 you'll find the SPI NOR chip backup of my working 70.00.352 EU and in post #84 a 56.00.513 EU of craz which should work (could not verify it so far due to probably other reason of my dead CMU than a bricked SPI NOR chip).
Edit1: And here you`ll find the original SPI NOR Chip content of working 70.00.100 EU & 59.00.502 EU (rename *.pdf to *.bin). Just in case someone somewhen needs it.
Edit2: I just did some tests with a working CMU.
a) 70.00.100 installed (reinstall + failsafe), value FF changed to 00 at line 0x010000. Request for reinstall was shown at the MZD display. At the inserted usb stick were both files of 59.00.502 and 70.00.100. The system chose the lower one to install (59.00.502). Afterwards the firmware was shown in the MZD 59.00.502 and the failsafe was still 70.00.100, but it worked. Then I manually installed the failsafe of 59.00.502 to be both 59.00.502.
b) 59.00.502 (failsafe+reinstall) was installed, I reased the SPI NOR chip and wrote the 56.00.513 file from craz to it. It worked.
c) With this working version from b) I tried to install FW 56.00.513, but it was not shown at the usb stick (as I expected it, as from 59.00.502 or + you can ot downgrade any lower than 59.00.502, but I wanted to try it.
d) With this working version from b) I changed the SPI NOR (56.00.513) value to 00 in 0x010000. Then the CMU requested a firmware file. It was not possible to update to 70.00.352, 70.00.100 and not to 56.00.513. For all three files the validation process started, but was canceled and I was requested to install the correct firmware. Instead of doing so, I erased the SPI NOR again and copied the fitting 59.00.502 backup back to the chip as this was faster than installing a new firmware. So it is also not possible to install FW 56 that way, if you were on FW 59.
... these are just my testing results of today. Perhaps they are interesting for someone.
Good job Tristan, do you have 2 dead CMU's now?
In version 56.00.513 you posted it was clear the system wrote reinstall.up and it was looking in USB for /mnt/sda1/cmu150_EU_56.00.513B_reinstall (1).up at location ( 0x07e000) instead of /mnt/sda/cmu150_EU_56.00.513B_failsafe.up
Following the instructions here Unbrick I checked all boostrap, ibc2 and failsafe sectors and they were identical with v56.00.513 except for those changes .
@dammy89 follow the same site and using a hex editor try restore those sectors in version V31 but read CHIP and save it first and don't forget to restore location 0x10000
Correct, I have the following CMUs to play around with at my bench setup:
  1. dead CMU, not booting, of an MX-5/Miata, SPI NOR chip erased without a backup (my first inglorious try with the chip clip).
  2. dead CMU, not booting, of a M3, 56.00.513B EU reinstall was at the SPI NOR chip originally.
  3. working CMU of a CX-5 (currently running 70.00.352 EU)
For 1. and 2. I was told by the previous owners, that the death came slowly. The MZD sometimes booted and sometimes not. They both did not install any tweaks or performed FW updates by themselves.
Thanks a lot for checking the 56.00.513 backup file (of 2. dead CMU). So, as the CMU is not booting with the original *.bin file and not with your patched one for the failsafe file, I guess we run out of options for fixing the CMU with some SPI NOR chip edits?! And as the death came slowly and the CMU booted sometimes and sometimes not - and only after that behaviour it was completely dead, I assume, that it is a bad/cold soldering, some burnt chip or some power or ground connection, which went bad over time. But I do not know where to start to measure with the multimeter, as there are so many connections on the platine.
It is strange, that the potentially wrong performed update to 56.00.513 has an uncommon file name at location (0x07e000): "cmu150_EU_56.00.513B_reinstall (1).up" - this indicates, that the dealer downloaded that file at least to times and chose to copy the file with the " (1)" addition to the usb and performed the update with that file first (which was wrong). I am glad, that I can update myself and do it correctly and not have to trust a dealer like that.
The dealership can not repair the CMU. They will offer you to buy a new one (1000 € at least). If you are still in warranty time, try to get one for free, but I doubt that you will. The other option to fix the CMU is the link to raoulh`s manual how to fix a bricked CMU with extra hardware (in the thread: Black Screen MZD). No other way is known so far.
CMU bricked repair
Hi,
Actually, your CMU is bricked. I did the exact same thing as you where my car was turned off just after installing the failsafe package. Luckily there is a way to recover, which is not so easy to do, bit it's quiet doable if you are not afraid to unmount the CMU, open it and plug some wires.
Full explanation:
Thanks to this website: http://www.2x4logic.com it saves me a lot of time to dig on how the system works. The CMU update process is indeed very badly designed, as it has plenty of failure points where it ends with a bricked device that will not boot anymore. The easiest way to do that is by shutting the CMU off after the failsafe package installation. Basically what happens is that a small flash chip that contains the boot program has a flag on it that decides on which system it has to boot. It can either be the normal Mazda system, or the «failsafe» software. When you install the failsafe update package without the 2nd reinstall package, the flash chip boot select mode is set to boot on the ibc1 partition, which does not match the current Mazda system. This ibc1 partition is updated by the reinstall package. So it’s bricked because it cannot boot anymore.
The easiest fix here is to change the boot select value on the flash chip to boot on ibc2 (the failsafe). This is normally done by the update process, after the reinstallation package is checked for integrity. Here we are going to do it by forcing the boot. It will start the «failsafe» installation software, that will tell us that installation fails and that we can retry by putting a USB key into the car with a correct reinstallation package. Then the installation will continue and finish.
Tutorial:
Here is a step by step tutorial on how to achieve this. Be aware that It can be hard to do this if you do not understand what you are doing. But in case your CMU is bricked (black screen after a failed upgrade or so) you have nothing to loose, right? Bringing the car to a dealer will not help, they will just charge you for a full CMU replacement, and that costs a lot…
The flash chip is placed on the back of the CMU’s PCB. It’s a NOR SPI Flash. The idea is to directly connect to this chip and use a raspberry pi (that has an SPI bus) to reprogram the memory.
Required hardware:
  • A raspberry pi
  • A Programmer Test Clip SOIC16 or 6x IC Test clips (I used test clips)
  • A breadboard to do the connections
On the raspberry pi, you need to install Raspbian (Lite version is ok). From a fresh install of Rasbian, setup the pi to have SPI enabled by running:
Code:
sudo raspi-config
(enable SPI in Interfacing Options*)
sudo reboot
Install some required tools:
Code:
sudo apt-get update
sudo apt-get install build-essential libusb-1.0-0-dev libusb-dev git wget curl libpci-dev
Get a newer version of flashrom:
Code:
git clone https://github.com/flashrom/flashrom
cd flashrom
make
sync
Shut the power off of the raspberry.
Now the raspberry pi is ready. Unmount the CMU from your car (look on youtube for video on how to do it, it’s easy), unscrew the PCB from the CMU and plug the wires from the raspberry to the flash chip like here (see attached pic) and http://www.2x4logic.com/mcbot-annotated.jpg
Turn the raspberry pi on. And check if the flash is detected:
Code:
cd flashrom
./flashrom -p linux_spi:dev=/dev/spidev0.0,spispeed=8000
This will tell if a chip is detected or not. If not your wiring is not ok. When something is detected, flashrom may tell you that multiple different chips are detected. That’s because some chips from a same manufacturer can have the same protocol. You need to read the right device model from what is written on the chip. I had a MX25L6445E. I know that some other CMU may have a different chip model. It should also work if flashrom can detect it.
Then try to read the memory and do a backup:
Code:
./flashrom -r backup-cmu.bin -c "MX25L6436E/MX25L6445E/MX25L6465E/MX25L6473E/MX25L6473F" -V -p linux_spi:dev=/dev/spidev0.0,spispeed=8000
Carefully read what flashrom is doing to check of any failure. I had to use the option -c "MX25L6436E/MX25L6445E/MX25L6465E/MX25L6473E/MX25L6473F" to select the right chip model in flashrom as it was written when using the -p option (list all detected devices)
Once you have the backup, we modify the boot-select byte inside the file
Code:
cp backup-cmu.bin cmu-mod.bin
printf '\x00' | dd of=cmu-mod.bin bs=1 seek=65536 count=1 conv=notrunc
Now it’s time to write the modified file to the flash:
Code:
./flashrom -w cmu-mod.bin -c "MX25L6436E/MX25L6445E/MX25L6465E/MX25L6473E/MX25L6473F" -V -p linux_spi:dev=/dev/spidev0.0,spispeed=8000
Read back the flash to verify it worked
Code:
./flashrom -r cmu.bin -c "MX25L6436E/MX25L6445E/MX25L6465E/MX25L6473E/MX25L6473F" -V -p linux_spi:dev=/dev/spidev0.0,spispeed=8000
Check if the file matches by verifying the checksum
Code:
sha1sum cmu.bin cmu-mod.bin
The checksum should match, if they do, the procedure is done. It’s time to unplug everything and put the CMU back in the car. The CMU should boot into the failsafe recovery system and ask you for a USB key with the reinstall package.
Good luck, and happy hacking! ;)
YOU ARE THE BEST MATE!!! I JUST RECOVERED MY CMU THANKS TO YOU. I will name one of my kids after you!!
CHEERS!!
I was had done afriting what you sayt but mij cmu was veledating the sofware but than it crascht what can I doe about that
@anaramir : Have you checked the checksum/hash of the downloaded firmware file with the checksum/hash from the inofficial server? I guess not - you should do that and most probably download the firmware again and check the checksum/hash. Then I would try it again. If that is of no success, or you do not want to, try freek`s offer.
Link to checksum/hash-folder
Looking for help... I had a failed fw upgrade from 55 to v70 when it was interrupted. Screen was black. I flashed the chip by changing the value at 0x010000 to 00. I am now getting a 'System Failure' message when car is first turned on. It will validate the v70.0.100A package but does not install and goes into a bootloop with 'System Failure' message. Is there a way I can start the fw upgrade from the beginning? One of the links here mentions corrupting the NAND flash to start the install process from the beginning. Has anyone tried this?
Furthermore, reading through some links, I replaced HEX values from an old failsafe.up firmware for the bootloader, ibc2, and fail-safe in an effort for the system to boot to the old firmware without resuming the update but I'm not sure the process of flashing that to the chip. I am pretty confident I am on version cmu150_NA_55.00.760A as this was the CMU data that was retrieved when I had AIO tweaks installed.
Not sure where to go from here, if I'm getting the resume failsafe installation message when I turn on the car then wouldn't it make sense that I am able to resume that update if I have both cmu150_NA_70.00.100A .UP files on my usb?
