1 - 13 of 13 Posts
the auditd0rk
After one week with the new wheels (18x7.5 5Zigen ZR+) I have one that is bent. I don't recall hitting a pothole and I'm usually quite careful when driving, but nonetheless one is bent pretty well.
The day after having the wheels and tires mounted I checked the tire pressure and found all 4 tires at 29-30 pounds each. Not only is the below Mazda's recommended tire pressure, but it seems rather low for 40-series tires. I immediately increased the pressure to 36 front and 35 rear and have managed not to damage any of the other wheels. I have Yokohama 225/40-R18 S-Drives and presume they are good tires that will protect the wheel.
Is it possible to bend a wheel through "normal" driving, hitting typical bumps with an underinflated low-profile tire? I was told the wheels are stronger than stock wheels and am now paranoid about bending any others.
Thanks
Resident MacGyver
Noo! Man, that stinks. I assume it is possible to bend a wheel if the tire is under-inflated. It's never happened on any of my cars though and the roads here are terrible. You'd have to hit a pretty big pothole. That's very strange. Good news is there are usually shops around that will bend it back for $70-80 if the finish isn't damaged.
If it's new it should still be under warranty.
BeEvil
Resident MacGyver
BeEvil
On his aftermarket wheels? I guess if there is some kind of roadhazard warranty on them (does that even exist?). Usually manufacturer's warranties only cover defects.
Sorry to hear about your wheel. There is no way you would have bent your wheel without knowing it.
5Zigen is a reputable wheel maunfacturer and they build quality stuff. Are the wheels new or did you carry them over from another vehicle?
the auditd0rk
Discussion Starter #7
They're brand new. Discount Tire is going to call tomorrow to see if 5Zigen will replace it under warranty. Seriously, though, I don't recall hitting anything that I think would bend the inside edge of the wheel. Colorado Springs has crappy roads and I've always been careful. Oh well, chalk this under sh1t happens.
the auditd0rk
Discussion Starter #11
Just got a call from Discount... 5Zigen will replace the wheel. Very happy, but still going to be paranoid about bending any others.
One 3, one 7, one fun!
Sorry for what happened
Sorry man, that just blows, especially on new rims...
I did bend one of the rims I had on my old car, but I hit a pothole so big (night time) that I destroyed 2 tires and I had to change a halfshaft seal...
And the rim just had a tiny ding, in fact I kept using it with no problems...
Does anybody else use your car?
If you keep the pressure around those values however, you should be pretty safe. Perhaps not on a pothole like the one I hit, but certainly on anything else.
1 - 13 of 13 Posts
