While I like the capacity of lithium batteries, I'm not a fan of them as a car battery. Lithium batteries don't do well in high heat or high vibration environments. Seen all those videos of people's phones and laptops bursting into flame? The last thing I want to see is my car burnt to the ground because I hit one too many pothole... The plain old lead-acid battery works just fine unless you have unusual needs, like a massive car stereo or you plan on camping in the car.
I hear ya.
But the only times i have seen an issue with lithium in cars if when using motorcycle batteries or batteries that have no low voltage cutoff or overcharge shot off.
Bikes shake alot. Once the voltage drops below 10volts charge you need to plug and recondition it back. It only becomes an issue in high amp charging when at 10v volts or below.
The cells cant take the amperage and battery starts melting. The lithium battery in phone and laptops is not same as LiPo in car/bike starter batteries.
Take it from experience. I had a shorai battery (4lbs /380CCA) that i let get too low a voltage and when she would not start i boosted with a portable lithium car starter
and melted into a jello ooze.
The anti gravity battery LiPo have a low voltage cutoff and overcharge shutoff. I replaced the shorai with an anti gravity 3lbs / 420 CCA
Shes a small and very light battery only worry is capacity. cant leave her parked for several weeks / month. Got to drive her once a week.
Hey Karl you know all those catch on fire Li batteries can be found in all new EV's ... they dont really talk about much about that.
We'll probably get used to it like we have with our gas cars and the explosive liquids we carry to run them.
At least gas dont explode when going over a pot hole ..
