1 - 8 of 8 Posts
Hi,
every two weeks my gfs car battery completly discharges. A quick look and you see the battery is dirty as all hell.
Step #1 Battery clean up with warm water and baking soda.
I want to remove the connectors for better cleaning but im afraid of losing the 12volt memory and resseting the car.
Question: Can i plug my cars positive battery to her positive connectors and my negative to her chassis so i can remove her battery?
Once clean i will hookup my motomaster battery charger
Font Gadget Automotive design Output device Audio equipment
This item claims it can detect faulty battery. Not sure if it takes into consideration for parasitic drops or alternator fault.
Any tips for furthur troubleshooting?
Cleaning the battery posts is a good idea. It's not uncommon for dirty terminals to leak power. Personally, I wouldn't worry about losing memories by disconnecting the battery, although you will have to reset the clock and whatever else your car requires. It's generally not a big deal.
I have seen devices that allow a person to remove the battery without having to reset things. I believe they use a small battery. You might Google the topic if you're interested.
About the idea of using a battery charger: I would be very careful. I've never tried to do it, but I would be worried that the battery charger's output is not very "clean," and without a battery in the mix to smooth out the charger's production, the car's electric system could be harmed in some way.
If cleaning the battery terminal doesn't improve things, you might try measuring the parasitic draw of your car to see if there's an abnormality. I've been told that the acceptable parasitic current draw of a modern car should be around 0.03 Amps (30 milliamps), but it can be up to 0.075A or even 0.1A in some modern cars.
New cars today have a growing number of electronic devices that have memories that continue to draw energy even after the key is off. Such parasitic loads can run a battery down in a matter of weeks, if not days, if the car is not driven regularly or otherwise charged or, alternatively, the battery is not disconnected from the system.
A charger can be a good diagnostic tool but the only way to properly test is a load tester. A good test would be to disconnect battery, charge it and then load test to see if it's holding.
2012 Mazda 3 GX MT5 non sky
How old is the battery ?
"Question: Can i plug my cars positive battery to her positive connectors and my negative to her chassis so i can remove her battery?"
I've used a battery charger to hold 12V on the system when I've replaced the battery on older cars. I haven't done it on the Mazda but I don't see why it won't work.
If there was a question of using a battery charger to maintain memories while there is no battery connected, it probably won't work, most battery chargers have some smarts to check that there's a good battery there before charging (they typically won't even charge an over-discharged battery.) If it does work, it could damage things, because, as mentioned, chargers may very noisy output, they may also have very high voltage output (16+v) with no battery load.
I tried doing that, and I don't know how you can do it without modifying the battery terminals so the battery charger keeps power, and you don't zap yourself removing the battery and/or re-connecting the cables. In the end, I lost everything and I had to deal with the rough idle for a few days while the PCM re-learned everything.
There's also the danger of your FOB not working because somehow during the removal process, the FOB was unpaired.
1 - 8 of 8 Posts
