not yet i tried to re-install but still same issueI'm hoping to do the v70 update for CP/AA soon too, but this is the first I heard of this issue...have you gotten this resolved?
No ,, my version ADRHave yu tried updating to the new v70.00.100 if you are in NA (US, Can, Mexico)?
There is a new version for NA systems. If you are in Europe, UK, Australia or NZ there is no update yet. See original post on CarPlay postNo ,, my version ADR
there is new update for it ?
Aftermarket or original camera?i tried everything ...
my camera still not working <img src="http://mazda3revolution.com/forums/images/smilies/frown.gif" border="0" alt="" title="Sad" class="inlineimg" />
orginalAftermarket or original camera?
actually i didnt add usb hub yet just updated my cmu to 70You said you tried everything, what happened when you add the hub and cables, Did you install AIO tweaks? As wonderful as the tweaks are sometimes don't play along especially with v70.
If you didn't add the hub yet you know you could downgrade to your previous 59 version , people have done it, just remove tweaks if you have them.
Another question is do you see a black screen when you apply reverse? Did you remove or move your CMU ?
So basically software is doing the job and switching but you don't see the camera. It's also a possibility that your camera coincidentally died. Did you move the CMU to do a serial hack? possible you dislodge a connector and that's all.actually i didnt add usb hub yet just updated my cmu to 70
and when i reverse the parking sensors screen is shown
i dont know how to downgrade to 59
i cant use tweaks also because ( 95% full space message shown )
thank you for your helpSo basically software is doing the job and switching but you don't see the camera. It's also a possibility that your camera coincidentally died. Did you move the CMU to do a serial hack? possible you dislodge a connector and that's all.
To downgrade is the same process as the upgrade but I wouldn't recommend it because you already messed with tweaks and you may run out of space ending up with a brick CMU. You should contact [email protected] tell him about your problem and the 95% full space message.
That's good, you don't need v70 now but if you plan to get AA/CP in the future I suggest to remove all AIO tweaks reset CMU to factory then install v70 again.I downgrade my CUM to 59 ..
my backup camera now works perfectly
any one know way it didnt work in 70 os ??
Thank you
Yes i already ordered usb hub for CP/AA and when it arrived i have to update it for sure but i hope it didn't have issue again.That's good, you don't need v70 now but if you plan to get AA/CP in the future I suggest to remove all AIO tweaks reset CMU to factory then install v70 again.
Nobody but you reported this problem and isn't something a reset or pulling the battery terminal wouldn't fix. I can't explain myself.
