1 - 11 of 11 Posts
My mazda has some rattle coming from the b pillar area while driving on uneven roads, this is especially noticeable during low temperatures. I've managed to locate the source - it's the drivers seat window. The rattle stops when I lower the window or push the window from the inside with my finger. Now here is the interesting part: the rattle usually stops after driving for several kilometers (probably due to the fact that the window gets heated up from the inside), therefore taking the car to the dealer to report the problem seems pointless, because the dealer always wants to recreate the rattle before they proceed with the repair. Did anyone have a similar issue and managed to fix it on there own?
I already had the b pillar disassembled, but I found nothing. I'm certain that the window or an element that is adjacent to it is at fault here.
I don't think so, my seals are not damaged by heat.
My rattle was from the seatbelt assembly inside the b pillar.
As I've mentioned before: the b pillar plastics had been disassembled but no loose elements were found.
I believe that the window glass or an element adjacent to it is responsible for the rattle, because when I lower the window glass all the way down or push my finger against the glass then the rattle stops.
I think I have the same problem, 2021 turbo 3. Still looking for a good fix. When I lower the window, even slightly or more, the chatter / rattle stops - as in when going over bumps and rough surface.
I tried lubing the rubber piece up top corner, temporary fix but noise is coming back . Inserted a foam in between the rubber piece and metal door top corner area, not really helping much either.
Thanks
Thanks
This rattle made me Crazy but i have fixed It.
Driver side B pillar rattle?
1 - 11 of 11 Posts
