1 - 8 of 8 Posts
I noticed a while ago but I am curious, how reliable is automatic transmission with sealed for life fluid? :whistling 1:
I heard that if changed it will slip and not change gears :001_unsure:
I noticed a while ago but I am curioius, how reliable is automatic transmission with sealed for life fluid? :whistling 1:
First I've heard of this, but am curious to learn more as well.
If it's anything like the "lifetime" fluid for the ZF automatics on BMWs, I'd go for a change at 150-160k km (93-100k mls) under optimal driving conditions. And probably not easily serviced, although possible- basically you can drain about half of the gearbox fluid but the small amount left in the (small) torque converter can't easily be drained. But that's just a guess.
My local dealer recommends a flush & fill before 60k km for the added warranty, as opposed to never changing the fluid.
A lot of folks in the previous generation of lifetime transmissions got new ones around 80k. So a good rule of thumb is to change the fluid between 40 and 60k.
-Kevin
For my 01' BMW, the transmission is sealed "lifetime" fluid ZF automatic. I have changed the fluid when 140k miles on the clock. It shifts smooth before and after fluid change. Now it has 160k miles on it.
I plan to have transmission fluid change on my M3 between 60 and 90k miles.
Reactions: trixx506
You realise that BMW eventually relented and suggested the ATF change at 160k km (100k mls).......stated in the service booklet for that generation of cars. At least that's what mine said in 2004.
I think automatic gearboxes thesedays are pretty darn reliable though. As long one isn't ragging on it when cold, it should stand up to a lot.
Discussion Starter #8
I guess I will try to change it myself, hopefully there is no filter.
For those wondering service manuals includes it
1 - 8 of 8 Posts
