21 - 24 of 24 Posts
I have mentioned that for me I would consider it a mistake to remove the OEM engine coolant-to-ATF cooler in place of an aerial style ATF cooler 'cuz it removes the early heat-up function that the OEM style cooler provides. BUT, I would add the aerial style cooler for three seasons of the year and I would add ball valves to make for easy switching-in and switching-out action...
Just adding this: I would also (in addition to the addition of the aux. air-to-liquid cooler in front of the rad) advocate exercising control over one or both of the radiator / A/C condensor fans based on monitoring the ATF temp (of course, also allowing engine temp control over same... and A/C system control over same) and then also actively controlling the fan to achieve no more than 185F ATF temp, if possible.
Banned
Engine Oil temperature with the sensor in the pan between 205-230F and the coolant runs 170-214F with IAT at about 0 to 30F degrees above ambient temperatures , 10-15% throttle plate position and steady highway driving 65-70 mph. There are lots of things the ultimately effects all the temperatures but these seem to be the range high and low after the engine and transmission reaches operating temperature for a drive cycle. I personally do not like to have the automatic transmission running fluid temperature more then 200F and ultimately at about 180-190F.
I don't believe in lifetime fluids so I want to change the transmission fluid and filter (2016 3 i Sport Sedan) Should I do this a couple of times to get all of the old fluid out,or do a drain and fill only first and then do the filter and fluid the second time? Thanks
gen3 mazda3's have lifetime tranny fluid?
cool!
how about coolant?
21 - 24 of 24 Posts
