I've weighed(lab scales) a lot of tires in my day, and tirerack is generally within +/- 0.25 lbs.A terrific idea to see what the 2.0L can do....zoom zoom
No plans to strip mine down to the bare bones to see how that might boost mpg, but I do want to drop some unsprung weight by replacing the oem 16 steel wheels (on the iSport) for something lighter. I'm anticipating a noticeable bump in both mpg and power (acceleration), but would love to hear if anyone has actually dropped significant rim/tire weight on the 2014 skyactiv 2.0.
Thx for sharing your take on tire rack.com--very helpful.I've weighed(lab scales) a lot of tires in my day, and tirerack is generally within +/- 0.25 lbs.
The tires on this car are avg weight but leaning toward light(the comparable Michelins are 21 lbs). That's basically how you achieve LRR aside from compound/construction.
Bridgestone Ecopia EP422: 20 lbs.
http://www.tirerack.com/tires/tires...del=Mazda3 5-Door&autoModClar=i Grand Touring
I'm interested in knowing the weight of the wheels and agree with you that this will likely yield the biggest bang for the buck.
I don't intend to drive around without an interior I am just curious how much this car can squeeze out of a stripped interior. Maybe just remove the seats and spare tire![]()
um yeah I'm not talking about replacing them with lighter alternatives.wheels
exhaust
battery
Those 3 will save you the most weight.
If you're driving at highway speed at the same speed(say 65mph) you are accelerating. F = Ma. I'd have to work out the calcs to see how much of a theoretical improvement it would be but you have to consider rolling resistance goes down, acceleration goes down(using less HP to move at the same speed), thus improving efficiency.exhaust won't actually save you any worthwhile weight, battery is a bit minimal too.
I've taken out 350lbs of plastic from my car and put back in another 130ish lbs over time.
The car will act faster (because of course it weighs less), but MPG gains ... minimal at best.
Even if you stripped out the whole interior in an average car, you typically won't see more than 1-1.5mpg in a city drive; and would see 0 difference except more noise rattles and ... more noise than is worth it (especially when on the highway there is 0 gain).
Unless you plan on racing the car; there's no reason to strip it. The weight has more affect on acceleration performance than actual gas savings.
Especially with how loud the car will be.
100 lbs out of 2900 is 4%. It all adds up!Yea I don't see you saving much weight by removing some interior parts. It's not like they weigh a lot anyway, so how much do you think you'll remove? 100 pounds maybe? That's a pebble in a pond vs the 2,900 pound car. It won't notice a difference and neither will you. Waste of time and broken clips, if you ask me.
LOL!You can rip out thousands of dollars of interior equipment to save tens of dollars of gas each year.
It's not only about saving $$, it's also about having to fill up less.You can rip out thousands of dollars of interior equipment to save tens of dollars of gas each year.
As a science experiment, you're probably better off booking some time at the track (ideally oval) and convincing a buddy or lady friend to ride with you. Set the cruise control and ride a couple hours on your own, fill up, and then ride with the 2nd person for the same amount of laps and speed. Your looking at 100-200lb differential, depending on the weight of your passenger and I think it's a pretty safe assumption that any MPG you lose with this additional weight will be almost the same as the MPG you gain the striping the equivalent amount of weight.It's not only about saving $$, it's also about having to fill up less.
I guess no one wants to strip their interior to test out the results. I might have to do it next week since work will be light.
I'm not considering keeping it long term, I want to see what the effect of weight is on this car combined with its highway aerodynamics
You may have better luck convincing three bags of concrete mix from your local HD/Lowe's to ride a couple of hours. Place one bag on each floormat. You have a choice of 50#, 60# and 80# each....... and convincing a buddy or lady friend to ride with you. Set the cruise control and ride a couple hours on your own, fill up, and then ride with the 2nd person for the same amount of laps and speed. .......
