1 - 6 of 6 Posts
Hi to everyone! It’s Michele (sounds like Michael) writing u from Italy . My dealer installed CarPlay with new firmware 700021 .
Is there a chance to enter into the test mode of Mazdaconnect as shown in the old videos on YouTube entering in the test mode to enable touchscreen while car is moving(videos was referring to v56)?
Or further does anyone tried to hack the system with aio in latest v7000021? Does it work?
Thanks in advance and sorry for my improvable English!
AIO works fine IF you ran the ID7 script before upgrading. Otherwise you'll have to use the serial port method.
No, Mazda patched access thru USB in v 59.00.502, you need to take the trim apart and connect wires from a USB->TTL adapter in the back of the CMU and run AIO scripts.
Pretty Cool Dude
Prior to v59.00.502, all you had to do was plug in a flashdrive with some files on it to add the tweaks. Because you now have >=v59.00.502 and didn't do the ID7 tweak before, you have to do the Serial hack located at https://mazdatweaks.com/serial
1 - 6 of 6 Posts
