This actually worked. Rear doors tapped into the LOC and then also powered by Rockford Fosgate. Sub works better with signal from C plug's blue leads into Channel 3, but it works well whether you fade to front or rear.What happens if you were to combine 6 and 8 like this?
Could you use 6+8 coming out of the male A plug AmpPro as your summed rears to feed into the LOC for your rear signal? And then the same combined pins out of the female to power both rear doors?
I have a question...do you connect the blue subwoofer line or disconnect it? My Mazda3 gs has no factory subwoofer.I'm going to put off trying to power the rears for now. I only have front replacements anyhow and I keep losing the sub signal when the rear doors are powered by the RF. That mono signal is a PITA to work with.
For now, what seems to be playing well together is this:
A) Tap the signal for the front doors and subwoofer from the black AmpPro 8-pin plug on the right.
B) If you're looking to replace and power the front door mids, use the female side of the green AmpPro 16-pin plug in the middle. Leave the front door leads coming out of the Bose from the green male AmpPro plug terminated/taped up.
C) Tap the signal for the rear doors from the 16-pin black plug on the left.
I think the non-Bose Mazdas are wired differently. On the Bose Mazdas, that blue wire can be a lead to provide a signal for an aftermarket subwoofer (from male Ampro), or if you wire the longer leads from the female connector, it will also power the existing Bassbox. In other words you would leave the long leads disconnected if your goal is to leave the factory woofer inactive.At least you’re getting sound. Either I have a shorted wire or the amp is defective.
Thanks! Yea I had a "no sound" issue when I was powering the shorter signal leads by accident. Let us know how it goes!That’s a pretty clean job with the wires. It looks professional. I do have a Bose system by the way on a grand touring hatchback. My plan is to use an amp with dsp built in, the Sony xm-gs6dsp. It should have been a clean and simple install, but it’s still not making sound. I’m checking my speaker connections now.
Thank you! Now to mount the amp and LOC to a rack and see if I can tuck that on one side wall of the trunk. Really looking forward to hearing what it sounds like with Centerpoint on low and using the new tweeters, mids, and center in the front. I was going to bounce back into the other thread for that. This wiring project was a lot of fun (and work!)Seriously.. you did a good job!
My suggestion for the 2019+ with Bose is to start with the Mains signals from the 8-pin BLACK harness and get that hooked up (close the loops on the gray and white leads, then tap in your wires into those loops. See images below). Then, if you plan on replacing any of the factory speakers, swap out the tweeters, center, and mids up front, but start by ONLY powering the mids (Orange and Brown) and center (Gray) from the GREEN harness (and subwoofer straight from the aftermarket amp). The cowls will be a PITA to swap out, and the tweeters, even new ones if you swap them out, won't benefit a ton from more power than the 25 Watts or whatever from the Bose.That’s a pretty clean job with the wires. It looks professional. I do have a Bose system by the way on a grand touring hatchback. My plan is to use an amp with dsp built in, the Sony xm-gs6dsp. It should have been a clean and simple install, but it’s still not making sound. I’m checking my speaker connections now.
Quick question...do you know the wire color for the left front door? There’s no sound there. My rights are grey. I get sound there...help
On my 8 pin you have the blue sub, yellow and black ground, and then whites and greys for the doors. So white.Quick question...do you know the wire color for the left front door? There’s no sound there. My rights are grey. I get sound there...help
That’s what I thought too. I’m starting to think I got a defective amplifier...On my 8 pin you have the blue sub, yellow and black ground, and then whites and greys for the doors. So white.
If you connect the white leads to the white leads, you should get sound from that speaker. If you do, then at least you'll know it's your amp.That’s what I thought too. I’m starting to think I got a defective amplifier...
